6.0 Suburban Build
Old 10-10-2017, 09:51 PM
joejamesatou's Avatar
Default 6.0 Suburban Build
Getting my 2005 Suburban 2500 hopped up this weekend. It has almost 200k miles but doesn't use oil, leak or show any signs of wear. Took it to Dallas Mustang (forgive me for the Ford place) for a before dyno pull. It put down 260 hp dead even and over 280 ft-lbs! No power above 5k rpm which I expected for stock. A solid baseline for a high mileage truck.
Parts to go in:
Brian Tooley Stage 3 Truck Cam. Specs are 218/224 .553/.553 113+3.
LS6 valve springs
New pushrods
Speed Engineering 1-7/8 inch headers
Dual 3" Magnaflow exhaust with manual cutouts and X pipe
E fans with 160 thermostat to replace the stock clutch fan
Powerbond Underdrive Pulley
Tune by AMP Performance
Will have a dyno pull again at Dallas Mustang after so place your bets.
Old 10-11-2017, 08:12 AM
LS1 KINGS's Avatar
Default burband
Sounds good !!!...
Old 10-11-2017, 03:16 PM
gesto's Avatar
My internet armchair dyno guess is 315/325
Old 10-18-2017, 12:50 PM
00pooterSS's Avatar
In for results
I'd guess 320/330 ish
Old 10-18-2017, 09:35 PM
Got it back from the shop tonight. Pulls like a totally different truck. Idles well and on ramps are officially a blast.
Have to find time to make it back to the dyno for the after test.
Old 10-19-2017, 05:40 PM
00pooterSS's Avatar
How does the lower rpm range feel with that cam? Does it feel like it's just as strong on the bottom end and gained all up top? For example, if you punch it from a dead stop, does it feel same/better/worse?
Old 10-20-2017, 01:06 PM
jmilz28's Avatar
My guess is it's probably the same or slightly better. Second part of that is it may be perceived as a bit softer, only in comparison because of how hard it keeps pulling now on up to 6k or so. Relativity can be deceiving here. In for before and after dynos!
Old 10-20-2017, 01:17 PM
00pooterSS's Avatar
I agree with all of that man. That's the kinda crappy part, perception will be a big player.
However if it wouldn't squeak a tire on take off before and now will, that would be a pretty solid indicator.
Old 10-20-2017, 01:21 PM
I'm back! After a few days of driving, yes, it does feel softer between 1-2k rpms. Maybe jmilz28 is right, but I also think the tune might have something to do with it as it wants to hold to on about 500 rpm's more per gear than it did before. I won't be going converter on this as it is a daily driver and I care more about mileage and my wife driving it than 1/4 mile times. I can see why people run one though with this cam.
That said mileage dropped about 1 mpg. I use the Automatic app and it is an OBDII reader. This isn't some "I feel like I gained 1 or 2 MPG" forum guess. It dropped 0.8 MPG on 2 round trips commuting from the previous week, same route and driving style. Not complaining though!
On the whole it feels really alive above 2500 rpm. There is no letup between there and 6000 rpm. And with the speed limiter gone let's just say that in the tunnel section of LBJ Express late at night it sounded like a NASCAR truck. The exhaust is moderate in daily low revving situations, and barks when you step on it. I have yet to open the cutouts.
This is still a massive 3/4 ton Suburban. Burnouts don't happen just by mashing it. It won't run a 12 second 1/4 mile. However, it is no longer timid at passing on a 2 lane. You push the pedal and they are behind you. Can't wait to get it to the dyno next week.
Old 10-21-2017, 09:55 AM
4EyedTurd1's Avatar
What magnaflow did you get? My wife’s Tahoe needs to breathe a little better
Old 10-21-2017, 10:38 AM
Dunno the part # but it is a dual 3 inch in, dual 3 inch out.
Old 10-23-2017, 03:24 PM
jmilz28's Avatar
I don't know anything about AMP. Did they do a street tune or all on the dyno? If enough time isn't spent on the tune while driving, you can be leaving some on the table as far as power under the curve, including MPGs, driveability, where the converter locks up, etc. They may have done all that well and you're just feeling the tradeoff of a(ny) cam in a big azz truck. Regardless, it sounds like you got a major upgrade that is almost like getting a new truck!
Old 10-23-2017, 06:00 PM
00pooterSS's Avatar
Really appreciate the breakdown and honestly that's what I would expect from that cam.
I've known Sam for 20 years (he's the main owner and the tuner). AMP is a VERY high end outfit. Not the type of place to leave anything on the table.
Old 10-26-2017, 01:20 PM
jmilz28's Avatar
Good info and good intel on AMP.
Old 10-26-2017, 05:47 PM
00pooterSS's Avatar
They build some killer stuff and Sam has always been known to make great power and retain durability. If you haven't heard of them you'd probably enjoy some of the stuff they do. Look em up on youtube or Facebook. One of my favorite things to watch him do is put 4x or so the power through stock parts that I ever thought they would take. He has been doing it recently with the shop C7 and it's cool watching the progress. He does it to KNOW what parts can take and what they can't. R&D
Old 10-27-2017, 09:50 AM
jmilz28's Avatar
Yeah, it's amazing the upgrades GM has steadily made over the last decade. GM Powertrain has always been good but not just the engine anymore. The entire driveline is now a fuggin awesome system instead of an awesome engine playing "What can I break next?"
Old 10-27-2017, 10:23 AM
00pooterSS's Avatar
LOL yep. They kinda went to extremes with it too. First they (trans and rear) were extreme ****, and now lets pump 1k hp through them and yawn.
Old 01-31-2018, 09:16 PM
Sorry for the delay! I totally forgot to update you guys. Short answer:
325 HP and 343 lb-feet. Dyno graph attached.
Mind you the drive shaft failed at that point and and made everyone crap their pants. I can tell you it pulls great now at every RPM. The cam makes a torque down low as well as up top. After driving it for a couple months now it is rock solid. The only action it has seen was a 6.2 swapped 2012 F-150 that got to see my tail lights from a roll of 50-100.
Minor annoyances. The e fans always run because the ECU was programmed to kick on at 160. The underdrive pulley makes the lights dim when you roll up a window at night. I drive faster so gas mileage is basically 14 mpg now, and on premium. Costco gas is my new friend.
Next up this summer, most likely a 243 head swap with NBSS/TBSS intake. Possibly a 4.10 limited slip rear. We shall see.
Attached Thumbnails 6.0 Suburban Build-img_20171030_144014.jpg   6.0 Suburban Build-img_20171030_143931.jpg
Old 02-01-2018, 02:50 PM
stoverz28's Avatar
Nice numbers!
So do you think the driveshaft was slightly out of balance and couldn't take the rpm or do you think it was power related?
I don't know if you mentioned in in the op but are you running cats?
Old 02-01-2018, 03:23 PM
I would guess the RPM as it was going over 100 MPH. And no, no cats. It does have cutouts and didn't have it tested yet with those open.
Quick Reply: 6.0 Suburban Build
