Any suggestions on what's wrong?
Fuse box diagrams from the owners manual: https://ls1tech.com/forums/showpost....89&postcount=2
The difficult starting could be a number of things. Mine was doing the same thing and it ended up being that the ignition module and coil were bad. I had aftermarket ignition so it was easier for me to test, I am not sure what you have to do. But it is definitely worth the money for an MSD 6AL and a Blaster Coil, they work wonders on your ignition. Check your battery cables. One of my cables was too close to the accessory belt and the belt rubbed on it and ripped a little hole in it...I had an arc of electricity shooting at my strut tower brace because of this!!!
Check all the ignition fuses inside the hood and inside the panel by the driver's side door also. My PCM IGN fuse was blown for some reason or another.I realize I repeated some steps you said you tried. But if your ignition is still messing up, you might need a new opti. I know a few days ago mine wouldn't even start! So I replaced the opti, TPS, IAC (TPS and IAC because I had a high idle problem), MSD 6AL, coil and changed all the fluids, plus the battery cables and I haven't had any trouble since.
One more thing that helps alot when determining why your car is overheating is to remove the AIR system. I got rid of mine because it was doing more harm than good. It helps with troubleshooting because essentially all those hoses are junk and don't have a point or function. You can get a writeup for this on CamaroZ28's LT1 Engine Tech forum.
