WS6 Formula goes 15.749 at HRP
So, was my first time out at the track since I bought the car. Got to the park, watched a couple friends swap tires, got in the staging lanes and waited for a while.
Finally was my turn to run, I was a little nervous. This was how the run went.
R/T .420
60 2.170
1/8 9.257 @ 72.47 mph
1/4 15.749 @ 65.48 mph
Clutch/slave cylinder went out on me and the clutch stayed on the floor. No pressure in the clutch at all, goes straight to the floor and stays there.
Looks like tomorrow, new clutch and slave go in.
Just thought I'd share that with you guys. Was a good time regardless, met some cool guys with LS1's. Also, props to Bryan (getdrugtoday) for giving me a call and making sure I had a way home before he left. I appreciate it.
R/T .420
60 2.170
Good to see you made it home. You need an alignment tool for the clutch that i didnt have... i lost it domewhere, but you'll love the clutch.. They say give it 500 miles to break it in, but i usual do it a little diffrent
If your cluctch sticks to the floor when you are driving hard, and does not when you are just cruising, you may want to check and make sure your hyd cable for your clutch is not near the header/manifold. If it is, this could cause your fluid to heat up and not function properly.
Originally Posted by 99 Pewter TA
When I had no pedal pressure mine Master cylinder went out. I fould this out after I replaced the clutch and slave. Good luck.
And I think I'll pass on the run with the liberty, my mom has a 4 cylinder Altima and I think I could set something up for Brandy.
