Need a shop for 383 offset ground setup
Old May 26, 2006 | 10:32 PM
xfactor_pitbulls's Avatar
Default Need a shop for 383 offset ground setup
Who should I talk to in the DFW area. If not here, how about houston? Just picked up a 6.0 longblock, and need to pick my path of either 370 bore, or 383 offset ground. Money is ready now, just limited. Max effort 11.75:1 compression and nasty heads and intake. Truth to the fact you cant use a 6.0 crank in a car? Havent confirmed that one yet.
Brandon
Old May 26, 2006 | 10:49 PM
Tony Shepherd's Avatar
www.portpros.com
Old May 26, 2006 | 10:53 PM
Thanks Tony! I will hollar at them next week.
Brandon
Old May 26, 2006 | 11:04 PM
_Zac's Avatar
TECH Pimp
Brandon
I use that **** in my Cobra..
Old May 27, 2006 | 12:20 AM
You must be drinking too, goof ball.
Brandon
Old May 27, 2006 | 02:43 AM
MrBill97396's Avatar
Xtreme Horse Power in North Richland Hills, give them a ring. They are a site sponsor http://www.xhpsolutions.com/products/xhp_block_mach.htm and well educated group of guys.
Old May 27, 2006 | 08:51 AM
twobit's Avatar
Brandon, believe the 01+ cranks will work in a car. The older cranks have a wider flange on the back.
Old May 27, 2006 | 09:32 AM
1936FordPU's Avatar
thats good news...wonder what year these are that the guy is getting...
Old May 27, 2006 | 10:41 AM
I have a pm into the guy, hopefully he will call back and let me know. Otherwise, I might change my order to a bare block.
Brandon
Old May 27, 2006 | 10:43 AM
Here is his reply,
"Brandon i thought that you could use the 6.0 crank, the part # is the same 216. The older 6.0 cranks stuck out past the rear engine cover. That part # is 215. See ya later this week.
Sounds like it is the right one, someone confirm the part #?
Brandon
Old May 27, 2006 | 10:54 AM
twobit's Avatar
That sounds right. Also I think the older 6.0 cranks can be used if your using a th350/400 or 4l80. The longer crank just elimates the need for the spacer that is required when using one of the above trannys. But if you go back to a 4l60e or 6pd the crank would have to be changed.
Here is his reply,
Brandon
Old May 27, 2006 | 11:10 AM
Thanks Clint. I feel better about it now, if the crank didnt work I was just going to do the 370, but now I will go ahead with the 383-387 somewhere.
Brandon
Old May 29, 2006 | 09:45 AM
1936FordPU's Avatar
Brandon
I want a shortblock then Brandon...
Old May 29, 2006 | 10:34 AM
I will talk to the guy probably tomorrow. I'll let him know to track one down.
Brandon
