Car antenna HELP
Old Sep 1, 2006 | 01:56 AM
ls12000's Avatar
Default Car antenna HELP
The radio antenna on my 00 T/A stopped working and does not go down anymore when the radio is turned off. I can still hear the motor working so iam thinking that the antenna may be off track and just aligned back in place. has anyone else had this problem and can this be fixed easily with common work tools. Any input would help thanks
Old Sep 1, 2006 | 09:48 AM
Saad06's Avatar
i just had the same thing happen to me today! gs;kdlhj!! i would also like to know please
Old Sep 1, 2006 | 11:22 AM
98 Raptor TA's Avatar
there's a plastic cable with teeth that comes out of the end of the antenna and feeds into the motor, it may have come out to far and now the gear of the motor isn't contacting it anymore. You might try getting someone to put LIGHT pressure on it while you turn the radio off and see if the motor will pull it back down. I unplugged mine and leave it down 24/7 cause i never really listen to the radio and it looks like *** when its up IMO
Old Sep 1, 2006 | 11:33 AM
CRAGER's Avatar
Administrator
Originally Posted by 98 Raptor TA
...I unplugged mine and leave it down 24/7 cause i never really listen to the radio and it looks like *** when its up IMO
Old Sep 1, 2006 | 11:38 AM
Brains's Avatar
The other problem is the plastic will actually come uncrimped from the antenna, or it'll break at some point. I've had to replace mine because of the latter.
Old Sep 1, 2006 | 11:42 AM
01FormulaTA's Avatar
you will have to replace the antenna,not the whole motor. I had the same problem a couple weeks ago and it was b/c my mast was bent. There is no way the white teeth are not making contact, they plastic cable is extremely long it is either broken or bent, but as long as you can still hear your motor working you can just order a new mast for pretty cheap(like I did) and you should be able to fix it in about 20 min
Old Sep 1, 2006 | 12:13 PM
hawgs's Avatar
Mine just started doing the same thing. Where did you order your new mast? I can hear the motor, so I assume thats still okay.
Old Sep 1, 2006 | 12:16 PM
I-10 b4c runner's Avatar
http://www.installer.com/antenna/power.html
Old Sep 1, 2006 | 01:52 PM
Hagarr's Avatar
Were you at 24 hour fitness Willowbrook during lunch today? That was my Formula parked close to you.
By the way I have the same problem with my antenna.
Brian
