First time vid of my HPE built LS1 heads/cam camaro
Hey Fellow Texans, please check out my vid and let me know what you think. Go easy on me it's my first time ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Video Here
Video Here
I would venture to guess 430-440 and that is with no Kooks on it, since it is not listed what all is on the car there is my guess. Scooter@MTI formerly Scooter@HPE made 465 rwhp thru a M6 with bolt-ons, Kooks, cutout, and the HPE 5.3 heads & the "S" cam.
The highest number I put down was 386 rwhp. That was with a bad sensor. After sensor was fixed, it put down 374 rwhp. That was with the cutout closed and 103 degree temps going through a flowmaster. I know the numbers are low, but I have to give Chuck credit for trying on two seperate occasions to get the numbers up.
Originally Posted by Strini SS
Cam only?
LS6 Heads
S-Cam
Underdrive Pulleys
Long Tubes
Ported Throttle Body
Ported Oil Pump
NGK Plugs
MSD Wires
Lid
Cut-out
wow there is somethig seriously wrong with that car man...That car should be makieng atleast 420...****..my small cam only ws6 made 403 with a cam way smaller than what you have and stock heads
Yes it is very frustrating. It is boggling Chuck too. He says he has never seen a car do what mine is doing with this setup. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
He thinks that maybe the forged pistons (weight) and the Flowtech Long Tubes (air restriction) are keeping the horses down.
Has anybody else had a problem like this? I mean the car runs great. I'm not used to a big cam so I can't tell you if some of the noises from the valve train are normal or if some of the hesitation while cruising at 70 mph is normal. But overall it runs fine. I had a question about my oil pressure running between 20 and 40 though. On the stock block it sat at 40 and cruising was at 60. You guys let me know if you can think of anything.
1 Post
dude you have problems for sure. Your dyno graph looks like a lie detector test. My graphs from every dyno I have done is perfectly smooth. You may want to get your tune checked out by someone else.
Thomas
Thomas
1 Post
I mean man I make more power than you with an LS6 cam 400rwhp, 390rwtq. Thats through a 12bolt with 4.10 gears. I would just have it checked out by a third party. Good luck.
Thomas
Thomas
Decent vid for your first try
. Do alot of people have those z06 (z/28) emblems? Def checkout the car as those numbers are VERY low. I wondered why you didn't spin hitting it in first leaving that stop sign...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
