Home Inspections
One of the entries said that something like seven windows had lost their thermal barrier capabilities. Does this mean I need new windows, or is there a way to fix that, or what? Just a little confused there.
One particular entry concerned me. It said that there was evidence the foundation had shifted in at least two areas because there was some cracking in the exterior brick. However, the inspection guy also wrote on there that he didn't feel it warranted any foundation repair and that special consideration should be paid to the maintenance of the foundation in the future.
What do you guys think?
Basically, you could take that inspection sheet to the owners of the house and say "Lower your asking price by $X,XXX because we have to fix x,y,z". Then it's up to them to lower the price.
Would you buy a Z28 with 30 some odd problems? The imediate answer isn't NO but you've got to have a very good contracting company evaluate that estimate and get a realistic estimate against the needed repairs. I would NOT let the option period expire with a wrap sheet like that man. Appliances are only warranted most of the time up to three years. If you are BUYing the property, I would buy new appliances anyway.
Electrical/Plumbing/HVAC is a different story. Depending on the problems they COULD be an easy fix. Could you get a big more specific with the HVAC/Elec trica/Plumbing?
As dry as it's been, a lot of homes are settling and causing the brick to crack. Call a mason and have the mortar pointed. If there are no cracks in the ceiling, there shouldn't be any serious foundation issues.
Home inspectors are bound by a set of rules and licensed by the state. They are required to report ANY and ALL findings, regardless of how small or trivial. Your inspection report should be pretty clear on where the questionable areas are and you should be able to assess the damage easy enough.
Home inspection is a great way to know if the home you are wanting is a deal or a dud ...
electirc was, no ground fault circuit interrupter protection for all recommended electrical outlets in the kitchen, wet bar, garage or the out side
living area floor outlet was not installed square with the cover and the outlet is not accessible
stairway light didn't respond to the control switch
heating, the filter is missing from the upstairs unit.
plumbing
water leak under the wet bar sink at the drain
master bath hydrospa GFCI protector was not found
cold water pressure is less than expecte at one upstairs bathroom sink
indications of electrolysis note at the water heater supply fittings evident mainly by rust and corrosion
however, no leaks are noted at this time
appliances
kitchen disposer is jammed
microwave oven operates more noisily than expected
lower oven light did'nt respond to the control switch
doorbell didn't respond to the control switch
smoke detectors were not noted in each of the bedrooms
@least 3 of the whole house intercom system speakers didn't respond to the control *****
parts missing from one automatic garage door opener and the chain is not properly engaged
the upstairs bathroom vent duct terminates in the attic
SORRY FOR THE POOR FORMATTING! It was from a GMail chat.
The house was built in 1985, 2600sq/ft, and a decent to good neighborhood. This is $155K.
Thanks for all the advice, guys! Don't know **** about the stuff myself.
This is just a code thing. GFI circuits are for safety and IMO a little BS but I'd still want them for code compliance and for resell. Have this addressed by an licensed electrician.
This is a 5 minute fix
Probably a bulb, no big deal but needs to be tested
It's probably missing for a reason, investigate...maybe the owner is just dumb though
plumbing
100 Dollar deal here for labor + parts max
When was the house built? Sounds like it was built before GFI code
Request a new H20 heater to be installed by Sears or HomeDepot
200 dollar deal max if you pay for labor and parts
What???
Bulb...
100 bucks max
I'd get new ones that are wired in series installed but that is just me. You can do cheaper single units for less. But seller should pay.
Not sure on this, probably under 500
Not sure here but probably needs a new door or some major repair, 300-500
That's just funny, that needs to be fixed before you buy it. Nothing like pumping the smell of a fresh dump all over your stored things in the attic. LOL
I AM concerned about the nine windows and the foundation problems noted, however.
The bathroom vent into the attic could be an issue as well. As if we don't have enough humidity in Texas...if there is hot shower humidity dumping out that thing every day you could be looking at wood problems. Make sure the wood in the vicinity of that vent looks and feels ok.
The foundation....well, you may want to get a foundation EXPERT to look at that one. That could really be huge in the future.
My own experience with inspections is positive - they typically find things that I wouldn't even know to look for. On one house it would have cost us around $10k for a new a/c and heating system plus some water damage repair. We offered about $12k lower, with the owner having the option to fix the stuff themselves. The owners said no, they weren't going to fix it, plus they counter-offered with a HIGHER price than their ORIGINAL asking price
DAmn, got my 9 month taxes due and it was almost $2900!
I decided against the house after sleeping on it some.
The advice here really helped me with the decision. A big thanks goes out to everyone who offered insight and knowledge.
