FS:Rotating Assembly $1000
Eagle H-beam rods with ARP bolts
Diamond Dished pistons (cc'd at 10.82cc)
Stock GM 3.622" crank
I have the bearings as well. The coating is worn off, but in otherwise great shape. Rod bearing clearance is already set with the bearings at .0026"-.0029" torqued at 75ft-lbs. All you would need to purchase is new rings and locks to put this all together in a motor. Although the parts are used, with the machine work already performed I think $1000 would be a fair asking price. I would prefer local pick up, but I will ship at buyer's expense.
Thanks for looking,
Kent
Which member, any N20 thrown at this and how much?
Specifics on Pistons... Are they the Diamond "Boost" Pistons?
Very interested in this..
For a 3.905" bore
1.310" Compression Height
.927" x 2.500" pin
8.6cc dish
2cc valve reliefs
I asked if they were "boost pistons" and she gave me the same answer I gave you. I don't know if you had a specific piston in mind or not, but I hope this helps at least.
Responsibility is a bitch.
