T rex, Comp 921's, hardened pushrods $600
Pulled this out of a car going back to stock. Everything is in awsome shape with only 5k miles.
New all this is $1100
Shipped for $620 or you pick it up for $600 call 972-814-4550 Juan
63-26921-KIT Comp Cams 26921 Dual Spring Kit - Suitable to .650 lift with more aggressive ramp-rate cams - Kit includes valve springs, titanium retainers, spring seats & valve stem seals. $599.99
99-PR7400 Thunder Racing Heat Treated Chrome-Moly Pushrods, 7.400" (Stock length LS1) $109.99
99-TR-TReX v.2 Thunder Racing Custom Camshaft
T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000+ converter on autos, 4.30's or greater depending on transmission. Works very well with nitrous and proper tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads. $389.99
Originally Posted by will350wax
well if it doesn't work out with the other two guys, How much parts and installation?
I'm pretty busy with fixin my TA i just bought so i don't have time to install it right now. it would have to be in about a week or two. But if you wanna buy the stuff today i'll do your install for $150 ($50 off my regular price) cause you bought the parts from me. OR if you wanna prepay the install i'll do it for $100.
I gotta buy books for my classes so i really need the money asap.
