Help!!! Trouble With MOTOR!
Old Sep 4, 2007 | 01:29 PM
  #81
BC 01 SS's Avatar
looks more serious than just a cam, and metal going through a motor couldnt be good.
Old Sep 4, 2007 | 01:54 PM
  #82
Blck_01ss's Avatar
Time to start on your next motor... Got another car?? lol
Old Sep 4, 2007 | 02:02 PM
  #83
mellowyellow's Avatar
Originally Posted by NickcZ28
Actually
No hes right ... No humor...
Old Sep 4, 2007 | 02:36 PM
  #84
Tootall's Avatar
looks like the dowel pin off the timing gear.
I wouldn't worry about the pistons being the same height. Spin the motor around, are they all moving evenly?
Start looking for a 02 and up 6.0 short block.
Old Sep 4, 2007 | 02:59 PM
  #85
The PAT WS6's Avatar
UPDATE: ok i found the problem, it was the dowel pin, on the cam and the sproket was completely loose and all 3 bolts. everything is fine and the motor is turning over by hand... now what should i do. should i put everything back together and clean it back up. and throw on a set of stock 241's?
thanks
Old Sep 4, 2007 | 03:02 PM
  #86
Deerhunter-Z28's Avatar
You should rebuild the bottom end, it might run for a little while but not for long.
Old Sep 4, 2007 | 03:07 PM
  #87
2 SLOW's Avatar
that's not what he wanted to here
Old Sep 4, 2007 | 03:17 PM
  #88
Tootall's Avatar
you need to rebuild the bottom end with new bearings. . . . . it's like talking with a mouth full of grap nuts.
If you're . . " really lucky " . . . . your filter might have gotten the big chunks. Either way, fix it now, and it won't be that expensive, . . . . or keep driving it, and it's just going to chew up things even worse.
Old Sep 4, 2007 | 03:22 PM
  #89
UTzo6's Avatar
LS7 Member
I doubt he heard anything right here. :shrug:
Old Sep 4, 2007 | 03:38 PM
  #90
2 SLOW's Avatar
oh wow, I am a dumb *** :420:
Old Sep 4, 2007 | 03:48 PM
  #91
thanks
Since the heads are off throw some comp oe 850's in there (lifters)... Dont you have 241's now ?
Old Sep 4, 2007 | 03:54 PM
  #92
EATON22's Avatar
Pull the oil filter and cut it in half and see if you see metal shavings or pieces in the filter. If you can pull the pan easily look in the pan for the same. If your car wasn't tuned with a wide band 02 sensor to set A/F ratio and your tuner was going of stock 02's you could have leaned it out and broke something. IT doesn't take long to spin a bearing or pull a ring land and then all heck brakes loose. I have seen it with many stock LS1. Good part is if you have to break it down; go back in with some good forged stuff- especially pistons and rods. Unless you are spraying or going forced industion the stock crank with 6 bolt mains is stout up to a degree.
Old Sep 4, 2007 | 06:01 PM
  #93
KWIKKAR's Avatar
Pat with those Eye marks on your pistons, its a FOR SURE thing that you bent a valve or two. You can't see them with the naked eye but take them to a head shop and they will tell you how many you have. I had elliotts portworks do my heads back in high school. I had about 4-5 bent valves, and didn't even know it and thats after the dealership changed all the pushrods twice. So I would have them checked out.
Old Sep 4, 2007 | 06:20 PM
  #94
WOTFMAN's Avatar
Set the motor on the stand and disassemble the rotating assembly. Clean and inspect everything meticulously. Specifically take pictures of the bearings, and rod caps, also look at the pistons and ring groves. This will tell you whether or not to put it back together. Take the pump pick up off and look at the screen. If it was mine it would be thrown in a vat, machined and align honed, resized rods with forged pistons and ARP rod bolts. New oil pump, lifters, cam etc and freshen up the heads if I was on a budget. You could do it right for about 1500 in parts and labor if you shopped smart.
Old Sep 4, 2007 | 07:04 PM
  #95
Reject's Avatar
i'd just forge it while im there, no sence in keeping stock **** if you can up grade it!
Old Sep 4, 2007 | 08:12 PM
  #96
01 Red WS6's Avatar
I don't see anything to worry about... That's what the oil filter is for
Just change the muffler bearings and it will be fine
Old Sep 4, 2007 | 09:12 PM
  #97
marlboro racer's Avatar
while youre in there might as well forge the tip. if moneys no object convert her to a dual tip set-up, forged of course.
Old Sep 4, 2007 | 09:16 PM
  #98
ok i got a set of 241's and im going to put my patiort extreme springs on there i cleanded the **** out of the motor bolt holes. etc. im gonna put everything back together. and flush the hole motor with some cheap oil and drain the hole thing out. and hope for the best.
it was just the dowel pin that came out how much damage could it really do if it was just attached to the oil plug the whole time?
Old Sep 4, 2007 | 09:20 PM
  #99
blown4.6's Avatar
I wish you the best hopefully none of the metal made it into your bearings.
Old Sep 4, 2007 | 09:37 PM
  #100
It was just the dowel pin that came out how much damage could it really do if it was just attached to the oil plug the whole time?
Your just gonna spend more in the end, but it's your car.
