Help!!! Trouble With MOTOR!
Old Sep 4, 2007 | 02:02 AM
  #61
mellowyellow's Avatar
I think you chewed some lifters ... your cam is most likely toast.... That sucks...
Old Sep 4, 2007 | 08:22 AM
  #62
NaSSty Nate's Avatar
Originally Posted by red90cobra
bout time you started on your stang
Still going to be forever before it even runs. I'm tossing the idea of making it a real nice chasis now and doing a ladder bar setup and putting a real nice set up in it. Or just throwing some stock style stuff in and putting a carbed n/a ls1.
Old Sep 4, 2007 | 09:56 AM
  #63
The PAT WS6's Avatar
do u think i messed up anything else with the bottom end? of just cam and lifters?
im about to go pull out all the lifters on the passenger side so i will let yall knw.
Old Sep 4, 2007 | 10:12 AM
  #64
NickcZ28's Avatar
Damn that sucks man, No offense but thats what happens when a bunch of kids with not to much experience do cam installs..
Old Sep 4, 2007 | 10:42 AM
  #65
Deerhunter-Z28's Avatar
Maybe I missed it but did you change the oil pump? I would say 99% you are going to need a rebuild.
Old Sep 4, 2007 | 12:00 PM
  #66
what do u mean bunch of kids haha ****. i knew what i was doin we had 0 problems this had NOTHING to do with the cam install.....
update: i pulled both heads and the lifters are fine. and there was no signs of any damage, it had to be something in the bottom end. someone recommended it was a cam dowel pin but i doubt it. i have pics of everything as wel that i will post shortly
Old Sep 4, 2007 | 12:02 PM
  #67
****... i just checked the ****** stock cam. it looks like it may be the dowel pin .....
Old Sep 4, 2007 | 12:04 PM
  #68
Reject's Avatar
lol cam installs are so easy even a cave man can do it!!
no seriously they rank up there with oil changes!
Old Sep 4, 2007 | 12:08 PM
  #69
this is what worries me... this is cylinder number 5 and 7 they are equal as far as height....
and here is the lifters they are fine...
Old Sep 4, 2007 | 12:23 PM
  #70
Sounds like a spun bearing, looks like you might have gone a couple teeth off on the timing chain.
Old Sep 4, 2007 | 12:34 PM
  #71
connexion2005's Avatar
Looks also like you had some valves contact the pistons on 5 and 7. I can't imaging valve float with those springs though...
Old Sep 4, 2007 | 12:41 PM
  #72
Reject's Avatar
could it possibly be the rod bolts stretching with such high rpm's on STOCK rod bolts/??
Old Sep 4, 2007 | 12:47 PM
  #73
WOTFMAN's Avatar
Instead of putting it back together pull the front cover off and pull the cam...Id bet the dowel is gone...with contact on 5 and 7....your gonna have to spend some money this time. Do NOT put stock lifters back in that thing with that cam. Pull your lifter trays out and check them for cracks.
Old Sep 4, 2007 | 12:49 PM
  #74
Yea, thats why I said he might have not ben "dot to dot" when he put the timing chain back on.
Old Sep 4, 2007 | 01:13 PM
  #75
NickcZ28's Avatar
I was messin with U Pat!!
Old Sep 4, 2007 | 01:17 PM
  #76
Hmm I see. Wouldn't that have made stupid sorry power though? Just curious...
Old Sep 4, 2007 | 01:19 PM
  #77
Reject's Avatar
taht's like advancing/retarding the cam. you change where the power is going to be made alittle. but with such a donkey dicked cam you dont have any error room
  #78
2 SLOW's Avatar
between this thread and every other thread where you try and be funny,
you really suck at making jokes
Old Sep 4, 2007 | 01:23 PM
  #79
Reject's Avatar
i laugh at them
Old Sep 4, 2007 | 01:28 PM
  #80
NickcZ28's Avatar
Actually
