Problems with rebuilt manual tranny
+1 for Jason at TDP. Great guy and he knows what he is doing. Not to mention he stands behind his warranties. Satisfied customer.
gues these last couple guys cant read what you typed.
redsox_ws6, why would you even call BS if you don't know what the car looks like?
If you spent the amount I did only to have to pull the engine to fix a coolant leak due to them installing the heads completely against my instructions. If the rear plug wasnt installed right and the $1800 clutch that you bought from them and had them install got oiled down and they wouldnt stand behind it? If you spent the amount I did to correct these problems and more?
Im glad your experience was better than mine as was others. My car was left with them based on there reputation and the end result was a mess.
I will end my rant with this post.
I would be so pissed off.... that is a bunch of bs from a shop that says they dont rip people off...just like that guy that is still waiting on his check for his cam
If that is the case, then this guy should have been getting the hook up....
https://ls1tech.com/forums/showpost....2&postcount=28
I have too many cars apart right now to take another apart. Ill have 3 put back together today and they will rack this car and have the trans out monday before lunch.
