How to remove rear axles
http://s221.photobucket.com/albums/d...od214infantry/
Rotate the posi unit 180 degrees and you should see the cross pin retainer bolt.
Remove the bolt (it's sitting sideways, parallel to the axles) and rotate the posi another 180 degrees and the cross pin should slide out of the unit.
Push in one of the axles (from the fender to the center line of the car) and the C-Clips should be in the center of the posi unit and easily removeable (one at a time).
