What shift point based on latest dyno . . .
2001 Z M6 w/bolt-ons, Hooker LTs, true duals, CAI & SLP lid, Lakewood Boxed LCAs & Spohn LCA brackets (welded), BMR single-adjustable PHR, Random Tech adjustable Torque Arm set to -2.5', stock springs front and rear w/stock shocks front & rear.
I've run this setup at the track (except the LCA brackets) on ET Drags w/51 pound weight each rear wheel (bad for starting momentum) and netted a 1.96 with a 2500 rpm dump. I need to practice my feathering on the clutch admittedly, but with the high rpm, my pedal floats (need LS7 or something).
I'm running 3360ish weight at the track w/me in the car and 1/4 tank.
Now I've got good tires (M/T ET Streets - 28x11.5x15) on 15x9 Convo Pros so I should be around 30 pounds per wheel. What else is reasonable I should do to improve traction AND at what point here should I be shifting?
Thank you.
agreed
You dont want it to fall into a LOWER amount of horsepower when you shift. Thats why when you drag race you shift beyond your power peak. The Best V8 Stories One Small Block at Time
