LS1 383 questions???
Old Apr 10, 2008 | 07:27 AM
avengedws6's Avatar
Default LS1 383 questions???
Im looking at an SS and it needs the motor rebuilt. Im considering going with the ls1 383. What is the bore I need for the stock block?? Im just un-certain on bore and strokes' for engines.
Old Apr 10, 2008 | 07:34 AM
DWZ28's Avatar
the bore should stay the same on a 383
your just increasing the stroke i think to 4.00" and 4.125" is a 406
Old Apr 10, 2008 | 07:47 AM
avengedws6's Avatar
so all Im changing is the internals?
Old Apr 10, 2008 | 08:06 AM
Duffster's Avatar
that and the tune and probably the injectors. . . wouldn't hurt to change the heads/springs/pushrods to allow it to breath more. might consider changing the timing chain. A cam is always a good idea (isn't this a vicious cycle?)
Old Apr 10, 2008 | 08:09 AM
avengedws6's Avatar
Well yeah, I know im looking at a complete engine build, but I was just wondering if the block will need to be bored and honed, or if theres no damage just through the internals in it and start on the rest? Say, hows your Camaro going?
Old Apr 10, 2008 | 08:18 AM
Mike96z's Avatar
Nothing needs to be done to the bore. You can hone the cylinder, that wont hurt. Dont blow nuttin up.
Old Apr 10, 2008 | 08:21 AM
avengedws6's Avatar
well hell. this is sounding better than what I was thinking.
Old Apr 10, 2008 | 05:57 PM
Greed4Speed's Avatar
Shop around. You'll probably find an assembled 408 short block for the cost of a 383 rebuild. Unless you do all DIY.
Old Apr 10, 2008 | 06:01 PM
_Zac's Avatar
TECH Pimp
383 is old school..
Old Apr 10, 2008 | 09:59 PM
mmorrison09's Avatar
go with a 408 nick!
Old Apr 12, 2008 | 01:10 AM
Duffster's Avatar
Just updated sig a few minutes ago 0.22 faster in the quarter and gained almost 2.0 mph. Still not hitting it hard enough (scared of breaking rear - but I got a 1.87 60')
Old Apr 12, 2008 | 08:02 AM
avengedws6's Avatar
well, if the block is still good I just want to use it. PLus I plan on boosting it also. I was just thinking a boosted 383 would be nice. And I just got the ok from the wife last nite on getting it. Hey Mike, still got that trailer?
Old Apr 12, 2008 | 09:36 AM
KCS's Avatar
KCS
Moderator
You're just gonna need the cylinders honed to about 3.905", to fit the slightly oversized pistons. No boring necessary. That, with a 4" stroke crank will net you 383ci.
If you're not too familiar with all the numbers and math and what not, send the engine out to a sponsor here on the site, like LME/HKE/W2W. Those three shops are very repuatable and will put together a well built shortblock for you.
One final piece of advice, since your adding boost try not to cheap out too bad. Nothing wrong with cutting corners, but on the crtitical parts like the crank try to get something nice. I've seen some of the cheaper cranks have some serious problems and just reflect poor quality.
Old Apr 14, 2008 | 04:12 PM
avengedws6's Avatar
heres the list Im looking at.
scat forged crank
eagle h beam rods with arp 2000 bolts
Diamond racing 7cc dished pistons
Total seal rings
Clevite H bearings
Old Apr 14, 2008 | 10:59 PM
enigmah's Avatar
383 and stroke it make a 408 look like nothing. well depends.. 408 is like getting a 427 *sarcasm* run once and turn it off *sarcasm* i would never run walls that thin but if you got the money go ahead!
Old Apr 15, 2008 | 12:03 AM
KCS's Avatar
KCS
Moderator
scat forged crank
Total seal rings
Clevite H bearings
Looks OK except for the crank. I am just wary of those cheaper cranks. I've seen a few potentially catastrophic problems from one of those "budget" cranks, and heard about many more nightmares. If you do get it anyways, check it over VERY carefully. Look for spots that may have been welded in the counterweights. Check endplay. Check that the rear flange is perpendicular to the crank centerline. Check that the oil holes are drilled correctly. I could go on, just check everything!!
Personally, I like Callies' Compstar cranks. Very high quality, very accurately machined, just a nice all around piece.
Old Apr 15, 2008 | 07:34 AM
avengedws6's Avatar
Well, I called a couple of shops yesterday and I found out some interesting facts. Im now leaning towards the 408 and low boost. The 408 is only $400 more than a 383, so why not just work an extra day?
Old Jun 9, 2008 | 08:16 PM
Nasty275SS's Avatar
so wut did u finally decide???
