Finished my economic stimulus carport.
I forgot ya'll way up north gotta worry bout that white **** flyin down from the sky. I haven't seen snow in SA since...'86?
Carports are against city ordnance in Arlington as well....
Being on a corner lot, I just about guarantee there is a 25' build line on top of a 10' curb and sidewalk easement for a total of 35' from the street. The house more than likely is at that build line. The carport is over it.
Is that thing level all the way across? I would be real worried about water/snow/sleet/ice if you didnt add a couple degrees of slope to it, especially with the sagging middle. Where do you think all of that stuff is going to gather?
LS1TECH & Trucks Sponsor
PLEASE! add at least 5 more posts to that thing between all of the others! I understand why you don't wnat them, but otherwise it will cause alot more damage that the weather would have when the first snow of the DFW winter hits it. A slope would have helped alot, and still would have needed more posts. . .there is no way that will handle the weight when it's flat
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
The driveway looks to slope toward the right of the picture and the fenceline shows this as well. The roof of the carport looks to be level as the fenceline is still going lower compared to the carport the further right you look. But, I could be totally wrong.
#35
I guess you can't tell in the pictures but it has a 7" slant from the front to back. Driveway has a 12" slant so i guess thats why it looks flat.
I'm gonna add another posts on each side and some angled bracing to stiffen it up abit.
Buddy of mine built a 30 ft wide one out of the same materials with no posts in the middle. Obviously it sags worse than mine but its been up for about 15 years now. Had the same sag the whole time. He said when he built it he thought about putting posts in the middle but decided he would if the sag got worse. never did.
#36
#37
ive built a couple for people when i worked roofing, they are easy to build but i would support the middle for sure, also be aware of winds it will rip the panels right off, might want to 2 more cross beams and screw into them...the sagging isnt the problem its the lack of rigidity that will cause the most damage, the sagging is more cosmetic and can be a problem down the road, if memory serves me i believe every 18in to 2ft your supposed to put screws vertically and between the 2 ribs horizontally on the outsides...where the panels meet the ends you generally put a screw every rib but thats just how ive built them, im guessing you have 18in wide panels?
#40
the panels are 3' by 12'. i screwed them down 4 screws per panel per beam, so i guess thats every 9".
Pickin up five 10' 3x3 sections tomorrow. two for posts and the other three i'm gonna cut in half to make arms going diagnaly from each post to each beam.
