Where Is Best To Get This A/C part?
I didnt imagine those Aluminum pieces would weld up very well. I'm entertaining the notion that buying a new one would probably be a little on the safe side and maye a few bucks more expensive than taking the risk of the weld, but thanks for the heads up on that 00pooterSS, every advice helps.
I have had it go both ways, I have had them repaired with zero problems and I have had them repaired and they leaked a little and took them for a second welding that fixed it, that is usually the cheapest option, a junk yard part would be just fine, its aluminum it dosen't rust or wear.
Have you tried the dealer, sometimes dealer parts will suprise you with how cheap they are, more often than not they are very expensive but every once in a while they will shock you, its worth a shot.
I did try the dealer. I had the part in hand, he took it, looked it up in a picturesque screen and told me that it's $77. Someone else here only got charged $72 a couple of years ago, but everything goes up over years except our paychecks.
eh just go get it, you will get charged at least half that for a used part or a repair.
The part pictured is a liquid line. It comes with the orifice tube installed, the pressure switch, and one o-ring.
The thing about aluminum is it can bend back and fourth several times before it breaks, when you buy a used one how many times has it been bent? No one knows.
I'd get a new one, and you need to order the o-ring by the evaporator seperate. (thats the one by the firewall)
Thank you 9000th01ss. Is that the official name for it or is there something that's in the mechanic bible like "high side line" etc?
liquid line = line out of the compressor going up to orfice
you said you took it to the dealer and they checked it out and told you how much it was, that is the best way to garuntee the right part and price, seriously though how much time have you wasted trying to save 20$ on this deal?
#32
