How fast can Chris go? WIN 100$$
The Closest guess will win 100$
Last month Chris Fowler drove his Xtreme HorsePower Silver Camaro 9.60@139mph and set a new LS1 NA pump gas record. The car has undergone modifications since that time(see thread..)
https://ls1tech.com/forums/texas-members/958687-quicksilver-gets-few-goodies.html
You have 2 chances to win. Ties go to the first poster. The current LS1tech member that can guess the closest ET or MPH ( Example... 9.655 @ 139.99) will win 100$ for each closest answer. All you have to do is post your guess in this thread. If you are really lucky you could win 200$ if you get both ET and MPH right! The cutoff time will be the day before the scheduled track date at 12pm. The tentative track date is August 8th, 2008 at Houston Raceway Park in Baytown, TX.
Of course, employee's are not eligible to win, although they will keep you informed via PM (1970judge or Xman) with your questions.
Edit: For those that do not know, we changed the intake setup on the car. It was a stock LS7 plastic intake with no cold air setup. Now it is the single plane intake with an elbow and a cold air pipe that leads to the passenger side bright light.
Keep in mind that the clock at the track records ET to 3 decimal places and MPH to 2 decimal places.
x.xxx @ xxx.xx
example: 9.599 @ 140.12
If you don't specify we will just add a Zero
x.xxx @ xxx.xx
