what air compressor should i buy for my garage at home?
If you can swing it get the largest tank possible. I have a Champion 2 stage7.5HP 80 gal. and it's still not enough. This bad boy will dim the lights in the house when it starts, but it will still run with a die grinder (air hogs) running.
So what I did was found a used 80 gal tank and will put that next to my 80 gal so I have a nice reserve of air on tap.
Craigslist is the best for used stuff, that way you can go and see what you are buying vs. ebay or online somewhere.
Good luck with your search.
How are you guys plumbing in your inline air dryers?
mine is like 15 pounds and need to be mounted somewhere but but I'm not sure if i should plumb to it from the tank with hose or pipe? I have the Home Depot 60 gallon jobber, loud as hell!
I had been using a smaller craftsman but upgraded to be able to sand blast and paint.
There is a reluator on the dryer top control oine pressure but I'm not sure how I should plumb up to it? Its a 1/2 npt I think feeding into the dryer and then 1/4 coming out.
The run of pipe allows the air to cool somewhat before it hits the filter. Most of the water drops out in the filter. I tap my air tools at this point, but I also have another feed that goes through 2 additional filters for painting. I used 3/8" fittings all the way to the hose connection. I use a 3/8" quick connect for paint guns, but use 1/4" quick connect for tools.
Excellent info thank you !!! I knew there was a reason for the copper tubing but wasnt sure. I have it tucked into a corner so I'll do a wrap around on the wall and get some length to the tubing, how long do you think is good for cooling? I'm going to keep the dryer and shutoff all in one spot next to it. (compressor) Or do you its better to locate on the opposite side? Its not like the compressor throws a whole lot of heat but to paint in the future as well. So more than one dryer before the paint gun is recommened?
sorry for the hijack to the OP
Grats Average_Joe on getting that sweet sale price. I'd say the OP would do well to check for one of those near him.
Thanks Camaroholic for sharing your setup information. I've got a perfect nook in the unfinished part of my basement that I'm seriously thinking about putting a smaller vertical 220v unit in. From the compressor, I would need to plumb about 15-20 feet of hard line through a floor/wall to the garage. I've been kicking around the idea of a remote power switch and drain valve. Otherwise I'd be going through the house and into the basement every time...
Do the inline oilers work well enough? Do they normally have some kind of bypass for when you just want to blow some dirt off something?
Thanks,
Dan
Thanks,
Dan
thanks for the info guys.
ive quickly realized $300 aint gonna cut it. im looking at $450 max now. i was thinking a 60 gal from home cheapo.
does HP matter? ive seen big tanks with small motors and didnt think that would be a good idea.
14.5 cfm at 90 psi. best bang for the buck. i challenge you to find a better one for this price anywhere.
http://www.harborfreight.com/cpi/cta...emnumber=92504
this one? http://www.homedepot.com/webapp/wcs/...3+90017+524403
slightly less air output but twice as big of a tank for relatively the same price. could be a good trade off.
I saw a thread on another board that Lowe's is clearing out their Coleman compressors, because supposedly Coleman declared bankruptcy. It's worth a look; one guy said he got a great deal, another guy checked his and they weren't discounted. But take a look at Lowe's.
I did a complete writeup with pictures and everything on my air system in this thread:
https://ls1tech.com/forums/tools-fab...-shop-air.html
