welding mild steel to chrome moly
Is this in a rule book somewhere? ive been getting conflicting information. My miller rep says to use CM rod. Ive read both all over the internet and im confused.. It makes perfect sense to me that you want a less brittle weld but where is it in the rules? also is the ER70s rod the same as E70S2 rod?
we use ER70s-6 where i work when welding P1-P4 material (mild to cr/mo).
Intuition would tell you to use the higher grade rod (80series) and you'd be ok, but that's not the case, you want 70s-6 with your Argon. In all honesty, 80s-b2 or whatever you may/may not have laying around would work, depending on what you're doing...assuming you know how to weld. IF you were welding something thicker that was a high heat pressure boundary, then you'd need some preheat on the material first and definately use the 70S.
I've got to weld some tabs onto my subframe connectors that are 4130 for my new torque arm mount. you can bet i'm not going out of my way to swap wire to do it either. it'll be fine, and if not, lesson learned and i'll do it with 80s-b2, not a big deal i don't think. the differences in composition between 70s and 80s are small enough that on something, or anything, automotive related that i don't worry too much. a roll cage maybe...but not little stuff, 1/4" and thinner. i don't think the loads and forces our cars put out, even in higher hp examples, are enough to really cause a weld failure. i would bet that in half the cases where a weld DOES fail on a car, it's either poor design to begin with, or the welder just didn't know what they were doing.
...just my .02 though.
