Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Is there an Air Compresor brand to AVOID?
Old Jan 5, 2004 | 07:49 AM
Reckless's Avatar
Super Moderator
Default Is there an Air Compresor brand to AVOID?
Going to finally get a nice compressor in the next few weeks. Good deals at Harbor Freight on Campbell Hausfield and others around also. Are there any brands to avoid?
Looking for about 70gal/7hp with oil and 230v.
Old Jan 5, 2004 | 09:25 AM
Pete2k_Z28's Avatar
It really depends on how much use it will see. If you're going to run the thing 24/7 don't get a CH. But for weekend warrior duty a CH will last a very long time.
Old Jan 5, 2004 | 01:21 PM
Reckless's Avatar
Super Moderator
It won't really see that much use. Home garage use, so definitely not full-time.
Old Jan 5, 2004 | 01:50 PM
2001 Pewter WS6's Avatar
Restricted User
That is a big compressor for part time home use. Anyway, my buddy who does body work at home just bought a 2 stage compressor with about those specs at Home Depot. It is a Husky Brand but Home Depot is very good about backing up their products they sell and he has been more than happy with it.
Old Jan 5, 2004 | 03:03 PM
BTL FED's Avatar
I would not get husky, we got 2 230v huskys back to back, and neither of them even lasted a full day before the motors burned up, and both were installed by qualified electricians
Old Jan 5, 2004 | 06:35 PM
Damian's Avatar
LSX Mechanic
I've heard the same thing about the big Husky units from some local audio shops here...
I've got a Craftsman that works great. 6.5 HP, 35 gallon. Had it for over a year now with plenty of time on it and no problems......
josh
Old Jan 5, 2004 | 08:37 PM
PlainwhiteZ28's Avatar
well i got a husky 5.25hp 26 gallon, seems to work great, made by Devillbis in the USA, I dont see a prob with it.
Old Jan 5, 2004 | 09:22 PM
Mike K.'s Avatar
I just got this one and it works pretty good for garage use
http://www.sears.com/sr/javasr/prod...session.new=Yes
I almost got this one though and it is more along the lines of what you are looking for.
Good price on this one too.
http://www.sears.com/sr/javasr/produ...id=00918419000
Old Jan 6, 2004 | 07:29 AM
Reckless's Avatar
Super Moderator
Harbor Freight backs up their stuff very well. The reason I like a big tank is because I do lots of fabricating which requires long use of the cut off tool. And occasionally I do some porting and polishing which also requires a big tank, unless you like to take lots of breaks. When you can get a 7hp/70gal for $400, why not? Bigger is always better, right?
Old Jan 6, 2004 | 10:36 AM
Ackattack1's Avatar
I have a 60 gallon husky. Haven't had a problem with it since I got it in August.
Old Jan 6, 2004 | 01:03 PM
Justin99TA's Avatar
Do not get an oil less compressor! I worked at Sears for over 4 years and they do not last like a piston oil type! They are loud and will not hold up near as long. I have read inside test by Devilbliss! As a matter of fact don't get a Sears either. They are over priced and you can get the same thing at Menards or Home Depot cheaper. Jus
Old Jan 6, 2004 | 01:53 PM
mitchntx's Avatar
You got it ...
I have a 6hp/60 gallon CH I bought at Tractor supply for $369. I bought it almost 5 years ago and have had no issues.
When I'm using my 4" right angle grinder, the compressor runs almost constantly.
Get as much capacity as you can afford.
Stay away from FarmHand brand, which (as I understand it) a cheaper version of CH.
Old Jan 9, 2004 | 02:23 PM
LS1XJ's Avatar
I have the big ole husky, like at the home depot. It is the biggest one, some stores don't carry it. From what I have heard they are made by one of the other companies. ANyways, it puts out a lot of air and works great.
Dustin
Old Jan 9, 2004 | 03:09 PM
16again's Avatar
Mine is a Husky, had it for over a year no problems.
Bob
Old Jan 9, 2004 | 07:26 PM
6camaro9's Avatar
I have 60gal, 7hp, CH Iron Force that i got a lowes and it works great.
thomas...
Old Jan 13, 2004 | 05:00 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah I got the CH one at lowes the 7hp 60gallon two stage for $569.00 works great the 7hp 60gallon single stage didn't put out the cfms to run continuous grinders ETC... That is also why I passed on the HUSKY. But between the two they put out the same cfm's and the price is almost the same Husky $398 Lowes CH $399? I personally like my CH. I don't think either one will give you problems for house hold use. Also the 80 gallon husky didn't put out as much as the CH but it had the 80 Gallon tank, I like the smaller compact one for space saving reasons. And I can personally tell you the CH I have is really quiet. Good luck! It is hard to make the call I just did it and it is working fine for me I am sure that Home Depot will stand behind the Husky and the CH sayes to contact them directly so who knows!
Old Jan 13, 2004 | 05:45 PM
Steve@SpeedTech's Avatar
I have a very cheap CH that I bought at a Wal Mart store that was moving locations and was selling off thier stock. I paid $159 for it and so far it has lasted 10 years with no problems at all. It is pretty loud but I simply built a box around it in the corner of my shop so its really not that bad. I never expected it to live as long as it has, but sometimes you get lucky!
Old Jan 14, 2004 | 03:35 PM
Hank Hill's Avatar
From: Grammar Nazi Regional Headquarters; Arlen, Texas, U S of A
I've got an ancient Craftsman compressor I picked up at a yard sale for $75. It pretty small and doesn't have a lot of volume or super-high pressure, especially for tools that blow a lot of air, but on the plus side it's an oil-type so it is extremely quiet compared to the newer Craftsman (or other brand) oil-less compressors.
At my cousin's home auto shop, where I do my bigger projects, he's got a massive Quincy that could probably power a 16-bay auto service center, so for 2- or 3-man operations it's nearly unstoppable, though it did cost a bundle ($2-$3,000).
My cousin's Quincy looks like this, and it's built like a tank:
Old Jan 15, 2004 | 07:22 PM
Ru2slo_99's Avatar
A friend of mine that owns a body shop said he goes to Sams Club and buys Black Max air compressors. He said they are tough and only about $600.
Old Jan 16, 2004 | 06:49 AM
BigDaddyZ28's Avatar
Stay away from the 'Oil-less' Air Compressors. They will die if you work them hard.
And when you do get an Air Compressor, Change the oil in it occasionally...
I work the **** out of a little 2HP Hitachi (been running about 7 years now) and it refuses to die. Why? Because I change the oil a few times a year. I work with guys using the same brand compressor (often theirs are newer than mine) and oftentimes if it is cold, their compressors won't run at all, while mine will crank right up (plugged into the SAME outlett) Reason: Their junk is ragged out from 'lack of proper maintenance' and/or abuse.
And a bunch of them just can't seem to understand why my compressor is twice as old but runs twice as well... Change the Oil!
