Good pulley puller and installer
does anyone know where i can get a good pulley puller that will work and not fall apart without breaking the bank and an install tool?
as for the install tool. just go to lowes and get a longer than stock crank bolt. it should work just fine!!!
I bought an instal tool from a guy on here that is a threaded rod with a nut and washers. It takes the pressure off the threads when pressing the pulley on. Drawing the pulley on with a bolt can cause some problems. My buddy found that out the hard way.
Mike
Mike
If you use the installer tools, ..., you thread the stud/bolt into the crank snout, then use the nut on the outside to drive the pulley on. No spinning threads in the crank snout until the final tighten of the end-use bolt.
Minimal risk in this manner.
http://www.spx.usatoolwarehouse.com/.../OTC-6667.html
This puller is 10x better than any garbage you're going to rent or buy at any parts store, it's much easier to use, and puts force on the pulley in the right places to make for quick removal. With the older 3-jaw pullers, you need a good bit of leverage to pull them off. With this puller I can use a stubby 3/8 ratchet and it yanks it right off.
As for install, there's 2 ways you can do it.
-There's a member here that sells a pretty slick tool for it
-Take a propane torch and heat your pulley snout up for a few minutes. Should slide on enough to start threading the stock bolt.
