Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What tools do you need to do a clutch?
Old Apr 9, 2004 | 12:12 PM
Dope's Avatar
Default What tools do you need to do a clutch?
I'm getting a new pilot and throwout bearing with my clutch kit, what tools do I need to be able to remove/install these items? I've never done any work with bearings before.
Maybe I'll post this in the M6 forum too.
Thanks,
Dope
Old Apr 9, 2004 | 01:36 PM
Brains's Avatar
Throwout bearing: 10mm wrench/socket/whatever.
Pilot bearing/bushing: Bearing/bushing puller. You can buy/rent these from the auto parts store.
Old Apr 9, 2004 | 02:37 PM
2000WhiteTA's Avatar
Go to Installuniversity.com and there is a step by step install of a clutch and it also tells you exactly what you need to do one. I hope you are putting in a single disc because a twin disc is a pain in the ***. Good luck and have fun
Old Apr 11, 2004 | 01:21 AM
Dope's Avatar
Single disk, and thanks!
Dope
Old Apr 13, 2004 | 10:03 PM
technical's Avatar
If you can get your hands on an old yoke ( eg. from a trashed driveshaft ) it will come in handy to keep fluid from coming out of the back of the trans while you are removing it.
Old Apr 14, 2004 | 10:55 PM
Dope's Avatar
Thanks, but this is actually a C5 with the tranny mounted to differential, no worries about fluid!
Dope
Old Apr 16, 2004 | 11:18 AM
Pete2k_Z28's Avatar
Dope, you're in for it on the C5. Don't forget the C5 clutch is at the engine, not hte trans. Exhaust gotta go, torque tube gotta go, that means the heat shield around the torque tube (with like 9,000 screws) gotta go.... Hope you got air tools!!! Have to be careful as well, if you let the engine tilt back too far you can do damage. Not to deter you, many people have done it successfully, but it's not an easy task.
Best bet is pull the exhaust, then the rear cradle, then the trans/rear diff. Then work on the torque tube.
Are you doing this on a lift???
Old Apr 16, 2004 | 10:47 PM
Dope's Avatar
Nope, jackstands. I'm not too worried, I have already replaced the rear diff. It involved dropping the mufflers, midpipes, rear cradle, and then tilting the torque tube down. This is gonna be the same deal except I remove the torque tube instead of the rear diff.
I've just never done a clutch before, I've always owned automatic cars before this.
Just need a little height and yer good to go
Dope
