Post your best welds!
Either way, I'd probably dial 100 amps on something that thick and use the pedal to control heat. I like to get a good puddle going and then I can pull the heat back from there to weld.
Chassis shop made me one for a glide but it won't work for the th400 so I made a new plate that will work with a glide or th400 so I have one universal mount, just cutting the old plate off and welding this one on. I will attach via a weld on both sides of the plate, and the small brace I'm planning to make will run along the bottom like a back brace. Something fancy/add a little strength to it just to be safe and because I have time.
I'm not really sure I understand what your making. But .062" thick sheet metal really shouldn't be used structurally in my opinion, and then if trying to do so, you have to add enough heat to actually add filler material and the work piece ends up warping and/or at least having some nasty tension in it. .062" sheet metal is typically "glued" together using a silicon bronze filler rod and low amperage to keep the HAZ small and the work piece it's actual original size.
I recall you mentioning that you are building a trans x-member. I'd probably be using .125" 4130 at a minimum on something like that. Depending on the size or span of the structural parts .125" will likely be plenty thick, however there are instances that .187" thick material would be useful. .250" is overkill in most all cases except extreme off road **** that sees ridiculous loads.
Here's the mounting plate I cut out the slots on the Bridgeport, it's slotted so I can put a th400 or glide on the same mount. Going to make a rib down the middle to add support once I have it welded on where I want to. I will have to trim it back a little opposite the slot I just wanted to leave it big, asi won't finish it until the motor/Trans is back in, hopefully next week
