Post your best welds!
the guy doesnt even wear a hood, just peek-a-boos it lol
pretty terrible welds, just godawful bird poo lookin globs
but he's dirt cheap and I dont have to get under there.
now would i let that guy weld on my turbo truck? nope. would his welds fly in my workplace? nope.
but, horses for courses and all that
@ 5spd-iroc, is that restricted 45* pipe the 6g test? you a pipefitter?
shearer. damn nice work pal. pulse? can I ask your settings? I'm newb to thin SS tube
Also I know i could slow down and be a little more uniformed but on thin wall i typically run 50amps foot to the floor and stack filler through the keyhole as quickly as I can to keep the heat/puddle looking right. Vbands around 70amps and turbo flanges 100-120.
Lets say you're welding two pieces of material together and to weld you plan on dialing 90 amps (and using a foot control) to make the weld. Double the amperage you would typically use, so in this case crank the machine to 180 amp. Here is where it gets tricky. If your torch placement is correct, you can basically slightly roll into the throttle for maybe half a second to make sure the torch is where it needs to be, then go WOT for a split second and release. If you did it right, it makes a perfect tack. This tip works good on steel/4130/stainless for example, but not so much on aluminum as I like to add filler to aluminum tacks.
Sometimes if the torch angle isn't right or the fit up is not perfect, the blast of amperage can just burn the two pieces away from each other, leaving a bigger gap to fill. So use this tip wisely.
I run a 200 amp Miller Dynasty, so I just normally turn it up to 200 amps unless I'm doing some thin wall exhaust tubing. But I've had luck using this method on **** as small as 16 gauge steel set up around 150 amps.
