Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Post your best welds!
Old Jan 6, 2016 | 03:03 AM
  #221
Blown06's Avatar
8 Second Truck Club
Originally Posted by ablakez28
That is nuts. I have used Praxair and Airgas and have never had a problem.
Also figured I would post that if anyone wants to see my welds I post a lof of the fab/turbo kits im building on my instagram but don't really often upload any online.
ablake211 if anyone wants to check it out. Just finished up a few f-body turbo kits that came out pretty cool.
Hell yeah, man. Post them up here. I'm one of those people stuck in a generation gap. Love the internet............hate cell phone social media.
Old Jan 7, 2016 | 12:18 PM
  #222
ablakez28's Avatar
One of the guys I made one for has some posted on another forum I will see if they can be posted.
Old Jan 8, 2016 | 12:41 AM
  #223
Blown06's Avatar
8 Second Truck Club
Not bad man. Steady that hand and get a rhythm going to clean it up a bit. But I'm not one to preach. I also need to steady that hand and get a rhythm going.
Old Jan 8, 2016 | 07:56 AM
  #224
ablakez28's Avatar
These were the first parts I have welded in a year believe it or not. I built this kit and another right after. My weld especially the aluminum really improved later in the process. Doesn't help these are being looked at so close. Welds look much more uniformed zoomed out a little.
Next week if I have time I will get some of the other kit up. My favorite part was that i did a freehand weave on the wastegates that came out pretty cool.
Old Jan 8, 2016 | 01:35 PM
  #225
LS1-IROC's Avatar
Nice! Whats your settings on that stainless?
Old Jan 8, 2016 | 02:14 PM
  #226
ablakez28's Avatar
Off the top of my head. These were prob on a #10 and #12 cup with gas lens 25cfh approx. Back purge around 3-5. 3/32 purple tungsten
130-40 amps on truck manifolds and the t6 flanges
60-75 amps on vbands
45-55 amps on thin wall tube
I tend to move the puddle very slow so i dont lack penetration especially starting the weld. I use a fair amount of filler as well. 1/16 308 or 9 depending.
Old Jan 8, 2016 | 03:56 PM
  #227
JL ws-6's Avatar
Race your car!
I used .040 filler rod, I find it's easier to get it to melt into the puddle, and I can run the current on stainless a little lower down around 40-45 I also bevel the edge when I prep the ends of the tubing as well, so there's a small V that I am filling with the filler. May also be a reason that I run the heat lower too.
Old Jan 9, 2016 | 10:33 AM
  #228
redtan's Avatar
Originally Posted by JL ws-6
New Britain CT. Little far away.
Not too far from Boston. Do you do jobs on the sides for fellow enthusiasts???
Old Jan 9, 2016 | 05:34 PM
  #229
JL ws-6's Avatar
Race your car!
I do stuff on the side yes, lemme know. For beer ;-)
Old Jan 10, 2016 | 03:57 AM
  #230
Blown06's Avatar
8 Second Truck Club
I agree with the smaller filler wire. Stainless doesn't seem to require as much power (amps) as comparable thickness steel or 4130. I've always used 1/16" filler on my stainless stuff, but I'm considering going to get me a spool (for a mig machine) of stainless filler that is smaller than 1/16" and I can cut off the spool as I use it.
Old Jan 10, 2016 | 08:31 AM
  #231
JL ws-6's Avatar
Race your car!
Not a bad idea. I bought some .040 from my local welding supply, and it was slot easier to deal with than the 1/16 I had.
I dunno if I'd wanna go much thinner, but I did find.023 wire from my mig was the way to go with sheet metal, and about 10 amps on the machine lol
Old Jan 10, 2016 | 08:54 PM
  #232
redtan's Avatar
Cool thanks. I'll PM you.
Old Jan 11, 2016 | 08:43 AM
  #233
ablakez28's Avatar
Most of the time I will actually leave the amps at 60+ I can tell by the puddle when and if I need more/less heat and I just use the foot control.
Old Jan 11, 2016 | 10:12 AM
  #234
ablakez28's Avatar
Here are a few other shots of the two kits I recently built.
Weaved in some wastegates
Old Jan 11, 2016 | 12:23 PM
  #235
MuhThugga's Avatar
You tiggers and your awesome welds.
My fluxcore MIG is jealous.
Old Jan 11, 2016 | 02:28 PM
  #236
JL ws-6's Avatar
Race your car!
Great looking work, guy I'm borrowing the diversion from offered it to me for what a new alpha goes for, I think I'm gonna bite the bullet and go for it.
Old Jan 11, 2016 | 02:44 PM
  #237
ablakez28's Avatar
Sweet deal! Mine has been excellent.
On the filler rod note above I like the thin stuff too. For me personally how rod flows has everything to do with where I am entering the puddle and how much puddle/heat I am willing to carry throughout the weld. I don't usually make a full bevel on thin wall since I can penetrate straight through a butt joint pretty easily. I prep/remove the burr on a roloc tan disc usually holding about 30* so it does leave a slight taper. But hardly a full on bevel like I would on thicker SCH work.
Old Jan 11, 2016 | 08:26 PM
  #238
JL ws-6's Avatar
Race your car!
I take the end of the tube after it's cut on my cheapo band saw and square it up on the disk sander (40 grit disk it cuts pretty well). Once that's done I take it and pitch it at an angle and quickly turn it and put a little bevel on it, and take a edge scraper to the inside to get rid of the sharp edge.
Tacking when I build headers I usually put stainless wire in the mig, tack with the mig, then when welding I will take the joint, put a 1/2 inch of weld, go around to the opposite side, do the same thing, and then will hit the tacks and grind them back and tig over them.
That's what I do. I have very little luck tacking with the tig welder, on anything other than thick wall stuff where I can blast a little heat at it and get a puddle that's not going to burn thru at 70-80 amps. That's me though.
Old Jan 12, 2016 | 12:26 AM
  #239
Blown06's Avatar
8 Second Truck Club
Here is a tig tacking trick I learned a while back that works awesome if you do it right.
Lets say you're welding two pieces of material together and to weld you plan on dialing 90 amps (and using a foot control) to make the weld. Double the amperage you would typically use, so in this case crank the machine to 180 amp. Here is where it gets tricky. If your torch placement is correct, you can basically slightly roll into the throttle for maybe half a second to make sure the torch is where it needs to be, then go WOT for a split second and release. If you did it right, it makes a perfect tack. This tip works good on steel/4130/stainless for example, but not so much on aluminum as I like to add filler to aluminum tacks.
Sometimes if the torch angle isn't right or the fit up is not perfect, the blast of amperage can just burn the two pieces away from each other, leaving a bigger gap to fill. So use this tip wisely.
I run a 200 amp Miller Dynasty, so I just normally turn it up to 200 amps unless I'm doing some thin wall exhaust tubing. But I've had luck using this method on **** as small as 16 gauge steel set up around 150 amps.
Old Jan 12, 2016 | 08:12 AM
  #240
JL ws-6's Avatar
Race your car!
I'm gonna have to try that. Maybe this afternoon if I can get in the shop before I go to work.... I'll post results.
I have a pile of 18 gauge remnants from my headers so I'll put her at 125 and see what happens (dynasty 165)
