Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Post your best welds!
Old Sep 26, 2014 | 10:49 AM
  #81
SNLPerformance's Avatar
Not too bad at all.
Old Sep 26, 2014 | 06:51 PM
  #82
honda_head's Avatar
looks proficient to me CB motors
Old Sep 26, 2014 | 07:27 PM
  #83
CBM Motorsports's Avatar
Well thank you guys. And since there aren't any bad comments yet (which I was waiting for), here is some aluminum I did about 2 years ago. I don't know why I don't have any new pictures.
Old Sep 26, 2014 | 11:35 PM
  #84
jlcustomz's Avatar
beauty isn't the most important factor in welds, though it can go hand in hand with really good weld quality. Things like proper penetration without burn through or thin spots & needed filler thickness for strength can be more important, especially with projects like most of mine that you need the weld to disappear after grind, sand & polish.
Course on something like a stainless pipe that you won't grind & will be seen, hard to beat a really awesome row of dimes look.
Old Sep 28, 2014 | 09:54 PM
  #85
jlcustomz's Avatar
A few of my welds after sanding & partial polishing. Got a few low spots I may fill in & re sand & polish.
One little tip I learned before & forgot was you can use aluminum on the backside of stainless during welding, which will help shield the air without additional backside purging & neaten up the backside weld where you didn't have a tight fit. The bends pictured here were made by removing pie cuts with a hand grinder & a 6" quickie disc, so they weren't all perfect fit. I didn't remember about putting aluminum on the backside till the last few joints. eh
Old Sep 30, 2014 | 10:08 AM
  #86
Some aluminum welding today at the shop.
1/8" aluminum
100amps wot
20cfm straight argon
2% Lanthanated Tungsten 3/32"
1/16" 5350 filler rod
Attached Thumbnails Post your best welds!-end-weld.jpg   Post your best welds!-top-weld.jpg
Old Sep 30, 2014 | 08:15 PM
  #87
honda_head's Avatar
1/8" aluminum
100amps wot
looks good
i have to make an intercooler this week, i'll post up some of my aluminum welds when its done. i'm a little rusty, so we'll see how this goes
Old Dec 3, 2014 | 06:15 PM
  #88
iHateCloud69's Avatar
a little light work..
Old Dec 6, 2014 | 09:33 PM
  #89
Rocknrace03's Avatar
im not nearly a good as some of you guys, but i do alright.
worked for fabspeed for awhile before deciding to go to school
Old Dec 6, 2014 | 09:46 PM
  #90
kelsey_canard's Avatar
Man, all that work looks great.
I'm just waiting for the sloppy mechanics to invade doh
Old Dec 6, 2014 | 10:18 PM
  #91
showdog75's Avatar
I'm 39 and all I've ever done is weld/fab work. Been a union Boilermaker for nearly 14 years. I'll post a link to some stainless tube welding I posted on a welding forum a few years ago. This is what I do pretty much day in day out.http://www.millerwelds.com/resources...t-I-do-at-work
Old Jan 21, 2015 | 02:31 PM
  #92
NSSANE02's Avatar
Man some of you guys are freaking incredible! I just started playing with the TIG process a couple weeks ago and I'm hooked (buying an HTP221 in a couple weeks)
I only have about 3 solid hours of actual welding but I'm getting the feel for it pretty quickly. Here's a few pics of some today, any advice on improvements is greatly appreciated.
Old Jan 22, 2015 | 08:27 PM
  #93
FMX05's Avatar
I'm no welder but one that I work with (petrochem plant) showed me how easy it is to practice the hand motion for "walking the cup" like you see in most of the stainless pipe welds in this thread. Hold a AA battery between your thumb and middle finger with your index finger resting over the end. Press it down on a piece of paper on roughly a 45° angle and practice walking the lines it makes in a zigzag just as those welds look. You can easily see the trace the sharp edge leaves on the paper. I thought it was a pretty cool trick and some of you hobbyist welders might be able to use it when you are bored at work.
Old Jan 22, 2015 | 09:46 PM
  #94
NSSANE02's Avatar
Your explanation of hand placement doesn't make a lot of sense with a real torch (index finger placement)
For some strange reason I have better results freehanding than walking the cup. I'm sure it's a lack of practice but still doesn't make sense to me. When you guys walk the cup, do you still use the same filler placement (at the center/base) or do you use a stitch pattern?
Old Jan 22, 2015 | 09:57 PM
  #95
FMX05's Avatar
It was more about practicing the wrist motion. It's a battery, not a torch. Maybe his method could be improved upon?
Old Jan 22, 2015 | 10:14 PM
  #96
NSSANE02's Avatar
Oh I see. I don't know, I'm the last person to be giving advice. It's probably me but I don't think the battery reference is good practice. There's no way I could hold my torch anywhere close to that position due to heat (I'd have to hold right behind the cup) that being the case, wrist motion would be completely different.
I'm not trying to be rude, just referencing the technique to my experience (which is extremely limited)
Old Feb 2, 2015 | 10:01 AM
  #97
I need to try this, sounds like it would work.
I have been wanting to take my "G" welding tests, but not sure how many I can get through. I am guessing the first 3 for sure..
They finally have a test facility in Dallas!! Wooohoo! Calling them now.
Old Feb 2, 2015 | 06:13 PM
  #98
jlcustomz's Avatar
Yea the battery is just an excuse to practice wrist motion. Could also do this with a pencil.
Practice is useful. The one season I took agriculture class in high school, they taught gas & arc welding. Since I had contacts & no useable glasses at the time, I couldn't arc weld. So I sat there for the whole hour for a couple of weeks inside playing with an arc weld simulator, which tracked your distancing & hand motion skills. I was bad *** on the simulator next to everybody else waiting a turn for a minute of real arc welding.
Still never used a real arc welder, but those hours of simulator practice came in handy on the gas welding, which came in handy for learning tig welding.
practice is practice, Wax on , wax off, kick ***.
Old Mar 6, 2015 | 07:48 PM
  #99
stoning_volcom's Avatar
Alot of the stuff i build is for subarus, but I enjoy fabricating all types of things.
Old Mar 7, 2015 | 03:06 AM
  #100
Blown06's Avatar
8 Second Truck Club
Is the same person doing all the welds posted above?
