Post your best welds!
and this is the result of a open root 4g smaw bend test. gonna buy a welder soon, getting ready to start mig in the fall, and tig next spring. Miller Matic, stick 6013 root pass at 90 amps, 7018 hot, fill, and cover at 145 amps.
That being said it was obviously too hot and I'm going to try it without pulse and lower amperage so I don't have to camp out as long to get melted. Would you suggest letting it rest to cool at all intermittently? Like giving it a minute or two break every now and then?
And thanks, I built that fixture after I realized it was extremely difficult trying to fit it all up by eye - trying to hit a moving target so to speak. I cut everything myself - they started as 45 degree mandrel bends that I cut in half, then I made a model in solidworks and 3D printed a fixture to position the bends in my chop saw to make the cuts. I cut them a little proud of the reference faces and did fit / final sanding while checking on the fixture. Worked worlds better than my first one that I tried to fit up freehand.
All of the faces serve as a reference for where the cut edges need to be for theoretical fit up. Some attention is required to keep the tube from slipping while cutting but all you have to do is flip the fixture around in the jaws to make your cuts, no careful realignments or thinking necessary.
Lots of gotchas during the process of building this first (successful) one. It's far from perfect but I learned enough to hopefully make the second one better.
very nice man, on the v band the start and stop, when you start up again start up on your last stop. That helps make the weld look like a single weld around the whole v band. typically when im welding a v band i weld a 80 amps but im not using all of that. that fixture for the collector is really cool
if you dont minf me asking were did you get that fixture? for the collector?
if you dont minf me asking were did you get that fixture? for the collector....
This is my latest project - I decided to try my hand at building some double slip merge collectors for my m3 swap project. 1-7/8" to 2.75" merge, which expands out to 3.5" then an anti-reversion back to a 3" vband. It isn't the greatest welding in the world but it's my personal best so far in terms of the fabrication effort involved....still a lot to learn.
Vband flange weld
I did some reading about the vband weld ahead of time to get some insight into managing heat input and hopefully prevent warping, but it still warped pretty bad despite my best efforts. I was able to bump and file it back to being pretty flat though, fortunately, so I think it will still seal. When welding, I clamped the other half of the flange on there and set the whole thing on a big aluminum chill block to help draw the heat out.
As far as weld settings:
-1/16" tungsten sharpened to a fine point
-.045" filler
- about 3/4 pedal with the machine set to 120 amps, 30 hz pulse with 50% on time and 20% background. I used the pulse feature to help keep the arc from wandering over onto the clamp since it was extremely close to the flange.
I'd weld about 1/2" at a time, stop and give it ~10s of postflow to cool it down, then rotate the whole thing around and weld a little on the opposite side to try and spread out the heat. My HAZ isn't that wide so I didn't think I was putting that much heat into it. I left the assembly clamped together until it cooled back down, but when I unclamped it the flange looked like a pringle.
Anybody in here have any tips for a noob on how to prevent warpage when welding a v-band flange?
Looking at pics 1, 3 and 4.........how the hell do you get to the inside to weld it?
Since my collector outlet is only 2.75", I couldn't get the jumbo cup / long stickout to work since I was left with very little room to manipulate the torch angle - the cup would keep running into the merge peak and the walls of the collector. If you rig up another gas lens on a secondary purge line to flood the area, maybe you could get away with using a smaller cup (like a #7 gas lens) but I haven't tried that yet.
I ended up using a 70 amp micro-torch with a 45 degree head from CK to weld the inside. It has a long pencil tip on it that makes it useful for getting into really tight areas. I had plenty of room to move the torch head around as needed, but filler placement is a little tricky because there's not much room between the cup and the work. You can get around that by bending the filler rod slightly at the end. With a good fitup, you don't really need filler but I figured it'd be a good idea to add some for strength and also so I had a little extra material to work with when blending the inside.
More than one way to do it of course - with more experience you could get by with less probably but I'm still on my way up the learning curve and have probably several dozen of these things to build yet before I would claim to have any idea of what I am doing.
Thanks for the words of encouragement
As for the fixtures, I 3D printed the cutting jig and machined the alignment fixture myself. Shoot me a PM if there's anything I can help you with.
Also, what is yalls preferred tungsten for welding stainless?
This is about 30 amps, 16 ga 304ss pipe, very good fitment no filler, alignment on the pieces wasn't perfect so some of the crookedness is due to that. back purging with Argon, same stuff I'm welding with. Standard tungsten that comes with a miller diversion 165, as that's what I'm currently borrowing, I believe it's the lanthanated blue one if I remember right
Flame away, like to hear from experts what would you do to make this look better, and be more sound. I'm getting pretty good penetration thru the material, can be a little better I think but I'm trying to keep the joints as tight as possible, can add a little more current if needed, or just go a little slower either I think would help the penetration.
