Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
***honduhhh_head's fab thread***
Old Feb 21, 2014 | 11:22 AM
  #101
honda_head's Avatar
Doing some test welds with my new custom tig cup from Toxicfab.com
Old Feb 21, 2014 | 08:28 PM
  #102
Anti_Venom99's Avatar
On My Way to see this **** in person lol
Old Feb 22, 2014 | 01:28 AM
  #103
Blown06's Avatar
8 Second Truck Club
Man you can really hang that tungsten out there with that cup. I assume it's a gas lense.
Old Feb 24, 2014 | 12:29 AM
  #104
Blown06's Avatar
8 Second Truck Club
Question about welding aluminum:
I've been practicing some and ran into an issue today (has happened before) where when I go to dab the filler rod, it starts to melt and ***** up the rod. It doesn't flow into the puddle. Also, when this is going on, it almost seems like the filler doesn't wanna flow at all, if the ball comes off the filler, no matter how much peddle I put to it, it doesn't seem to flow then boom it goes flat. Also in this situation I seem to be getting a ton of contamination that seems to come from the filler. What gives?
Old Feb 24, 2014 | 08:27 PM
  #105
honda_head's Avatar
I'm using a #9 torch, so the lens isn't all that big, however the cup expands to the size of a #12 cup on a jumbo lens.
try pre-heating the area with the arc, without actually trying to penetrate. do this for a few seconds, then create a puddle that can be manipulated with torch angle, and now add your filler. this should help clean up the filler, because the a/c inverter is cleaning the material before you're trying to add contaminated filler. make sure your filler hand/glove is free of dirt (i have separate welding gloves and fab gloves, some guys use rubber doctor gloves on the filler side when welding aluminum). if this doesnt help, i have a couple other things to try too, but do that first.
Old Feb 24, 2014 | 08:30 PM
  #106
honda_head's Avatar
Old Feb 25, 2014 | 12:10 AM
  #107
Blown06's Avatar
8 Second Truck Club
I'll give that a try and post some pics for ya. Thanks for the tips.
Old Feb 27, 2014 | 12:06 AM
  #108
Blown06's Avatar
8 Second Truck Club
Hey thanks for the tip about using the torch with a little pedal to clean the base before welding. I haven't run a bead yet, but I did tack some stuff up tonight and it did make my tacks look better and the filler flowed in no problem.
It definitely works better than throttle down and jamming filler in to start.
Old Feb 28, 2014 | 11:26 AM
  #109
honda_head's Avatar
no problem, glad i could help
  #110
honda_head's Avatar
Old Mar 1, 2014 | 01:19 AM
  #111
Blown06's Avatar
8 Second Truck Club
I did some aluminum welding last night and seemed to notice that the welds got a lot nicer the more heat I added and the faster I traveled.
Old Mar 5, 2014 | 08:05 PM
  #112
honda_head's Avatar
It should leave almost a polished cap on them.
Old Oct 1, 2014 | 07:01 PM
  #113
honda_head's Avatar
bump:
Some recent shots
Old Oct 1, 2014 | 07:05 PM
  #114
TMTMTL's Avatar
Looks good.
Old Oct 7, 2014 | 07:55 AM
  #115
Valkyn's Avatar
Honda_head do you have a shop down in Surprise? I live up in Wickenburg and might have a few fab projects for you!
Old Dec 2, 2014 | 01:27 AM
  #116
Blown06's Avatar
8 Second Truck Club
Whatcha been up to lately?
Old Jun 5, 2015 | 01:31 AM
  #117
honda_head's Avatar
bump
been helping out on Anti Venom's build... check it out
https://ls1tech.com/forums/forced-in...5-6-speed.html
Old Jun 5, 2015 | 04:38 AM
  #118
t_raven's Avatar
Dang nice welding man. Keep it coming.
