Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Crank pulley installer - JCW $27
Old 10-27-2004, 03:31 PM
  #41
INMY01TA's Avatar
Originally Posted by robertbartsch
...........uhg!
Dude I had one and it wouldn't reach the threads in the crank. Do you actually have one? Have you actually used it?
Old 10-27-2004, 04:32 PM
  #42
2xLS1's Avatar
You are beating a dead horse. According to him, everyone that bought my tool still owes me $4.
Old 10-28-2004, 11:19 PM
  #43
robertbartsch's Avatar
Yeh, I have one and have used it on my LS1; works great. The treaded rod that fits the snug nut for the pulley is approximately the same diameter size as the insert that has the threads that match the ls1 crank bolt. The rod goes right through the center of the pulley... no problem... really!
You probably are using the kit from JCW that is desinged for use on AC and power steering stuff. You can;t use this kit for the crank pulley install.
It does not bother me at all if you guys are buying the $27 threaded rod and bolt. Hey, what ever works.... As long as you are not screwing up the crank threads you should be happy AS A CLAM in ****...
Old 10-29-2004, 03:46 PM
  #44
INMY01TA's Avatar
It wouldn't fit in there with that lock retaining ring that is used to secure the insert to the rod. Must not have had the lock ring on there.
Old 10-29-2004, 06:12 PM
  #45
Worm's Avatar
Are clams in **** happy? What a funny expression. I know I wouldn't be if I was in ****.
Old 10-31-2004, 04:45 PM
  #46
BigDaddyZ28's Avatar
Sort of funny when you catch people telling stories about stuff they know nothing about...
Like a deer caught in the headlights...
TTT
Old 11-01-2004, 05:49 PM
  #47
INMY01TA's Avatar
TTT
Who?
Old 11-01-2004, 08:49 PM
  #48
Who?
I was referring to Robert talking about things he does not know anything about.
Read some of his posts and you will see what I mean...
Old 11-02-2004, 12:22 AM
  #49
BLASTER's Avatar
Yeah, I've read alot about the JCW and heard that it just dosen't work because isn't long enough too.
I just installed mine with the threaded rod I made it and it worked great. I used it as the base for my puller to get the stock one off and then used it to put the ASP on. Got it on in less than 5 minutes. There's nothing like doing it the right way. Thanks 2xLS1 for the tip on the length.
Quick Reply: Crank pulley installer - JCW $27
