Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Floor Jack
Old Jan 20, 2005 | 11:05 AM
zdawg28's Avatar
Thumbs up Floor Jack
Just picked up a new very light weight race floor jack from Harbour Freight (link below). All I had before was a cheap on from sears(with the removable handle) which was nearly half the price of this one so its a step up for me. After i pulled it out of the box i was stunned, anodized blue and the rest was raw aluminum... . The best part of all is that i didn't have to run the front wheels up on boards and then start lifting, which alsways had to do previously. My z rides on the Eibach pro-kit in the rear and coil overs up front, which I had set slightly lower than the stance of the pro-kit so it works on lowered vehicles too...in case anywho ask . Someone else on the site mentioned and I would like to thank them for that.
Check it out:
http://www.harborfreight.com/cpi/cta...emnumber=91039
Adam
Old Jan 20, 2005 | 02:51 PM
absolut_speed's Avatar
Post back in 12 months when it begins slipping or a weld breaks. They're cheap for a reason.
Old Jan 20, 2005 | 04:26 PM
Armageddon's Avatar
...with cheese.
I bought a craftsman $99 floor jack and it's awesome. It's great for low clearance and it's got a quick lift to it. Highly recommended.
Old Jan 20, 2005 | 04:39 PM
mitchntx's Avatar
I had gone through 3 of those "cheap" jacks. And when one fails, it's never a good thing ...
I finally decided to buy a REAL jack and bought one of these ...
http://www.asedeals.com/hydraulicjacks2.html
DK13HLQ is an awesome jack, able to lift up to 38" high and only needing 3" of clearance. 6 yers later and it's still working like new ...
I did buy one of those HF lightweight jbs for use at the track. But for everyday shop use ... a good jack pays big dividends ...
Old Jan 20, 2005 | 04:42 PM
Armageddon's Avatar
...with cheese.
i was going to buy one of those... they are just too expensive. The craftsmutt works fine for me. Good warranty too.
Old Jan 22, 2005 | 12:51 AM
Muffracing's Avatar
I bought an aluminum jack from Homier (traveling tool sale) for $100. It's the same one Speedway Motors sells for $160. I've had it for about a year and a half, and it works pretty good. The saddle keeps breaking every time I get a load off center though. Not something I trust if I have to crawl under something. I really need a set of stands.
Old Jan 22, 2005 | 06:53 AM
mitchntx's Avatar
Here you go ...
http://www.pitstopusa.com/detail.aspx?ID=17367
Old Jan 22, 2005 | 11:54 PM
aresixx's Avatar
the harbor freight jack is fine for LIFTING....never work on a vehicle that is on ANY jack, cheap or expensive. always use stands!!!
Old Jan 23, 2005 | 08:42 AM
Nine Ball's Avatar
LS1Tech Co-Founder
ALWAYS use stands if you are under the vehicle. Never trust your life to a simple jack alone. If the hydraulics fail, or a bolt comes loose, or a weld breaks, you could get killed.
Just a reminder
Old Jan 23, 2005 | 12:04 PM
bigdsz's Avatar
FWIW, a friend of mine who was an airline captain for National Airlines was working under a car he was restoring and the jack collapsed, no jackstands, his spinal cord was severed. He has been in a wheel chair for the last 35 years, since 1970. NEVER get under a car without jackstands.
Old Jan 24, 2005 | 11:01 AM
DaveX's Avatar
I have one of the aluminum harbor freight jacks also. It's a decent jack for the price. I also have a 3 1/2 ton michelin jack from sam's club ($59) that is well worth the money.
And nobody should ever get under a car with only a jack holding it up. If I have a big job to do I'll put it on jack stands and keep jacks under it just in case, and sometimes ramps under the tires as well.
