Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
anyone do their own powder coating?
Old Mar 29, 2006 | 07:55 PM
gabeg94z's Avatar
Default anyone do their own powder coating?
im thinking of buying a powder coating gun from sears for $140 and a oven at like a resale shop to cook the powder, would it be worth it? or should i just send my stuff off to get coated. or is their actualy good products to buy to do my own powder coating? lmk guys thatnks!!
Old Mar 29, 2006 | 08:50 PM
DV8's Avatar
DV8
i do.
i use eastwood's stuff and its real simple. i did exactly what you were talking about for an oven. its a good amount of work (especially for proper metal prep), but i feel its worth it.
here's an example:
Old Mar 29, 2006 | 11:43 PM
gabeg94z's Avatar
that's awsome, were do you get the paints from?
Old Mar 30, 2006 | 12:26 AM
DV8's Avatar
DV8
eastwood.
i've also seen some reasonably priced powders on ebay, but have never tried them.
Old Mar 30, 2006 | 12:43 AM
gabeg94z's Avatar
you think this is a good gun, or worth the money?http://www.sears.com/sr/javasr/produ...id=00917288000
Old Mar 30, 2006 | 07:35 PM
DV8's Avatar
DV8
i've got a coworker interested in that gun. it looks interesting seeing as how you don't need an air compressor. for about 190, its worth a try.
Old Mar 31, 2006 | 12:50 AM
robertbartsch's Avatar
Harbor Frieght sell a gun for $69 bucks!
Old Mar 31, 2006 | 06:06 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I also use the Eastwood System and my wifes' old electric oven as our new house has gas oven. You definitely don't want to use your oven that you currently use for cooking
Don't see why the Sears gun wouldn't work fine - cost isn't too bad...
DV8- when you did yor calipers, did you disassemble them first or just mask off the critical components? Always wondered if the seals in the calipers could take the PC cure temps.
Old Mar 31, 2006 | 06:47 AM
618HAWK's Avatar
Used the Harbor Frieght gun and some of there paint as well, with good results. A good outcome has a lot to do with application and baking vs just the spraying.
Old Mar 31, 2006 | 11:36 AM
gabeg94z's Avatar
cook time is 30 min right? also when i spray the rims do i have to ground it?
Old Mar 31, 2006 | 04:45 PM
pnhigg's Avatar
The SEARS gun works very well, cleans up easy, and covers quickly.
Good luck
Old Mar 31, 2006 | 10:16 PM
618HAWK's Avatar
I would go off of the time limit or until it flows out. Once it flows out stop heating. And yes it needs to be grounded when spraying. That is the function of powder coating. Hang off of a grounded metal rack or clip the ground in a non conspicuous area .
Old Apr 3, 2006 | 07:17 AM
Lasershop's Avatar
I get all my supplies from caswellplating.com. I got the harbor freight powder coat oven 2 years ago on sale. It gets hot enough to cure ceramic coating as well. I find I use it for a lot of things. Pre heating aluminum for tig welding or just general paint drying.
