cornwell tools tap and die sets
lot of taps and dies onesy-twosey before you caught
up to the kit price, and personally I find I use only a
few; hell, older Chebbies only use a couple of SAE
thread types, the new ones a couple of metrics, etc.
If you know you'll be working mainly on certain models
or makes you will probably be buying a lot of pieces
that just sit, with a kit, and would probably be better
off buying the ones you know you'll need, with spares
(cuz they will break 2 minutes after the hardware store
closes, you know).
Take a look at somebody elses's set and just buy the
sizes that have bright threads, in his.
For a long time I bought what I needed, and will say that the stuff that the local ace stocks are actually some of the nicer taps/dies that I’ve used (hanson stuff mostly, the rigid stuff is nice also, much more so then the big tool truck stuff), and what I ended up with is a good assortment of handles and taps that I use most of the time, and then I bought a pair of cheap Chinese ones to fill in the sizes that I didn’t have and rarely use. I’d bet that I have less then $100 in the pile.
If I could justify the cost I’d probably go with a complete rigid or hanson set if I was going to get them all in one lump…
