Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
any experienced pipe welders in here?
Old Jul 31, 2006 | 01:18 PM
xfactor_pitbulls's Avatar
Default any experienced pipe welders in here?
I am working with 6"-10" sch/40-sch 80 mainly. 6010 5P+ root, with 7018/8018 cap. I have the root down, and the top half of the cap down. Just am having some issues getting my flow evenly distributed with the 7018 on the bottom side of the pipe. I keep getting a crown and want it to lay more rounded and flat. Turn the heat from between 100-130 amps with an 1/8" rod and its about the same thing. Do I need to focus more on the arc gap length or angle of the rod, or what? Going back to work on some contracts toward the end of the week, and this is the only thing I am not totally comfortable with.
Brandon
Old Jul 31, 2006 | 07:30 PM
Mr Incredible's Avatar
It's been a while, and it was mostly flat and vertical, but my best 7018 work was at a lower temp that got good connection to the sides but didn't get the puddle too excited. Can't remember the heat, and didn't do pipe welding. The passes were flat as a calm lake and the slag peeled up behind the weld and I just brushed it away.
Old Jul 31, 2006 | 09:47 PM
Thanks for the feedback, but pipe can be a bitch as far as angle of work and prep. Flatwork is MFing gravy compared to working with this oil field pipe. When I have the pipe on rollers and just work the top 1/8 of the pipe its perfect, and yes the starch removes easily compared to 6010/6011.
Old Aug 1, 2006 | 06:12 AM
99.9percenter's Avatar
Angle of rod!! On the underside of the pipe you need an aggressive weave pattern,this will require more heat to avoid cold lapping,lack of penatration.
Old Aug 1, 2006 | 08:08 AM
Gawd I miss the welding days!
Old Aug 1, 2006 | 05:33 PM
jdustu's Avatar
werd...more heat and quicker weave....i know some people run stringers all the way out to avoid that crown......like you said, the angle is pry the toughest part, not just upt and down but side to side as well....it's easy to lose orientation coming around a pipe.......
Old Aug 1, 2006 | 09:14 PM
What? Are you guys saying more heat than 130 amps with a 1/8" 7018 cap? Thats a fast burning and high shield rod, its hard to imagine hotter than that for a cap. I will give it a whirl tomorrow and see how it goes. On the bottom of the pipe I need to advance the hand and leave the rod behind or vice versa? For the weave keep an arc gap or drag? Dragging seems to make it more prone to pool on the bottom side. The single most important thing to what I am doing is uniformity, without that I am going back to the house.
Brandon
Old Aug 3, 2006 | 12:03 PM
jdustu's Avatar
Brandon
i've done mosly tig when it comes to pipe welding, but the last cert i did for stick was a 4g......7018, 1/8" ;the guy doing the testing said he'd go at least 130, and i was leaving the rod behind and keeping a super short arc, practically pushing the rod into the weld.....he also suggested doing stringers for overhead, it just sags way to easy with a weave.......the guy that certified for 6g(stick) that week did stringers all the way out.....
Old Aug 3, 2006 | 04:15 PM
TheOutlaw's Avatar
Brandon
Hold your sides a tad longer
Old Aug 3, 2006 | 04:28 PM
jdustu's Avatar
i had an instructer at the tech center ask me this:
"say you and two of your buddies are in the front seat of a truck driving along a dirt road and sharing a bottle of whiskey.....the bottle goes back and forth from one side, to the middle, to the other side, to the middle, and so on...they all take the same amount per chug, who gets the most drunk?"
well, the guy in the middle.......keep the bottle on the sides longer to even things out
Old Aug 4, 2006 | 09:28 AM
jdustu's Avatar
Brandon
how'd it turn out brandon?
Old Sep 1, 2006 | 09:20 PM
MikeGyver's Avatar
I've never heard of using 1/8" 7018 for pipe welding. I and everyone I've ever seen welding pipe use 3/32". I've never welded schedule 80, though.
