Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
need help with stuck head bolt
Old Dec 4, 2006 | 10:32 AM
N3V3RL8T's Avatar
Default need help with stuck head bolt
A guy I work with gave me a 95 chevy cavilier the other day. its a 4 cyl auto with 101k miles and a busted head gasket. my problem is that two of the front head bolts are seized and the 15mm studs are rounded. Ive already broken two 3/8 impact sockets and a 1/2" impact just rounded the nut. what can I use to get these head bolts out? are there special tools for this?
Old Dec 4, 2006 | 10:41 AM
we_todd_did's Avatar
Yes there made buy snap on and blue point the dig into the metal, or you can drill the heads off and use a stud remover to get them out when the head is off.
Old Dec 4, 2006 | 11:13 AM
N3V3RL8T's Avatar
i think ive seen these made by craftsman. has anyone used these? the snap on guy dosnt come until wednesday so im goin to sears today
Old Dec 4, 2006 | 02:48 PM
NBM01Z's Avatar
yea its called an extractor, good luck
Old Dec 4, 2006 | 03:12 PM
DRVETTE's Avatar
7 Second Club
You may be able to put a air hammer on top of the bolt head and the pounding will sometimes release the bolt, but if you rounded the head off already then your gonna need that extractor nut deal that snap on has.
Old Dec 4, 2006 | 08:20 PM
Armageddon's Avatar
...with cheese.
Use an air hammer first... by all means. Try a twist socket too.
Old Dec 4, 2006 | 09:17 PM
Jokeman's Avatar
PB Blaster and an OA torch.
Old Dec 5, 2006 | 03:45 PM
yak's Avatar
yak
plus one for the air hammer. I had a headbolt on a vw get rounded once. spun it with an air hammer to break it loose then I cut the head with an angle grinder so I could get a bent prybar in there to twist it the rest of the way out.
Old Dec 5, 2006 | 08:31 PM
Platinum WS6's Avatar
lol.........
Snap On is your best friend!
Old Dec 5, 2006 | 08:40 PM
Air's Avatar
Air
wally world cheap socket.
welder.
biggest breaker bar you own
problem solved.
Old Dec 5, 2006 | 10:48 PM
G-Body's Avatar
sawzall wielding director
+1 on the air chisel, I`ve had good luck getting bolts out with it. Even ones that still had a good head but the impact just didn`t have the power.
Old Dec 6, 2006 | 04:39 PM
N3V3RL8T's Avatar
snap on man came today and I bought a blue point twist socket and it got both out in about 10 sec. befor that I went to sears and bought the same tool but craftsman and it broke in 10 sec.
Old Dec 6, 2006 | 06:27 PM
sunsetta's Avatar
Drill the heads off, but make sure you use a center drill to get a start for the regular drills so they don't walk. Drill at a slow speed because they are hardened bolts. You can do it. Once the bolt heads are off, you can get the head off and the get a Pipe Wrench on the remaining stud.
Old Dec 7, 2006 | 07:24 PM
N3V3RL8T's Avatar
bolts are out... cracked head.... shat...
Old Dec 8, 2006 | 08:35 AM
Specialized's Avatar
Weld the block/head! It's all iron!
Edit: Go to the junkyard and get yourself another head, its cheap enough!
Old Dec 11, 2006 | 11:57 AM
DBUS6's Avatar
1x ^^^^
But try to use "cobalt" drills designated w/"CO" they have a gold tint to them.
also use some WD-40 to keep from burning them-up
Old Dec 11, 2006 | 07:36 PM
Armageddon's Avatar
...with cheese.
Junkyard time...
