Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Best Tool to take of side post battery?
Old Feb 18, 2007 | 12:14 PM
blk97z28's Avatar
Default Best Tool to take of side post battery?
i have a side post battery i have never known what tool to use? This may be a dumb question so delete thread if needed.Devin
Old Feb 18, 2007 | 12:40 PM
slayer_taunu's Avatar
its 5/16". i use a ratcheting box end wrench, but you could also use a socket.
Old Feb 18, 2007 | 02:53 PM
Full-Force's Avatar
5/16 or 8mm and it should not get rounded off
Old Feb 18, 2007 | 02:56 PM
blk97z28's Avatar
alright thanks man i'll check it out!devin
Old Feb 18, 2007 | 06:53 PM
Alt's Avatar
Alt
If you have a square head on your post instead of a hex you can also use a refrigeration wrench. Its like a ratcheting box end but for square heads as opposed to hex.
*I threw that information out there because I have seen batteries with square post heads*
Old Feb 19, 2007 | 04:26 PM
davered00ss's Avatar
Moderator
craftsman actually makes a wratchet wrench for it for like $5. I use an 8mm or 5/16 gear wrench.
Old Feb 19, 2007 | 07:21 PM
eschoendorff's Avatar
Knipex cobra pliers.
Old Feb 19, 2007 | 08:09 PM
blk97z28's Avatar
Got it all fixed up my battery was 100% dead and idk if it is the alentaor or the b/c it was like 20 below here in LINCOLN,NEBRASKA for like 2 wks?
Old Feb 22, 2007 | 12:48 PM
BaddillaK's Avatar
at the shop i used to work for we had a Bluepoint (cheap Snapon) wrench designed for the side post ... its about 10" long ratching box end and the handle is rubber coated from end to end it was a real nice tool to have especially since i tend to hit both terminals at the same time
Old Feb 22, 2007 | 06:02 PM
blk97z28's Avatar
thats pretty kool to know thanks!
Old Feb 22, 2007 | 09:39 PM
Specialized's Avatar
Autozone sells a side post battery terminal wrench as well.
They are the **** when doing batteries, I use it all the time.
Old Feb 22, 2007 | 11:11 PM
77montecarlo's Avatar
hmm, good question actually. also, i was wondering how i use my eyeballs and also my un-common sense. what is tools? i no think good.
-joe dirt
Old Feb 23, 2007 | 08:31 AM
BaddillaK's Avatar
Found that side post tool i was talking about and it was cheaper than i expected Im probably gonna order one later on heres a link
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Feb 23, 2007 | 06:26 PM
Moderator
That's cheap for snap on.
Old Apr 26, 2007 | 07:53 PM
blk97z28's Avatar
hey thanks i switched to these bat-lock things they work great and they come off with out a tool at all
Old Apr 26, 2007 | 09:18 PM
realmendrivev8s's Avatar
Thanks for the link, think I will pick one up tomorrow.
Old Apr 26, 2007 | 10:05 PM
blk97z28's Avatar
i may have to switch mine now and pick one of those up haha!
