Want to buy a small milling machine
Does anyone use a small mill at home? I do not want and cannot afford the room for a large Bridgeport or anything like that. I want something for making small pieces, modifying the odd thing, making tooling, etc. Manual is fine but it would be nice to upgrade to some simple CNC stuff at some point. Anyone else have something like this?
We have a Brigport and a couple larger horizontals in our shop. We pic up used stuff areound here all the time. Im in Houston TX. If you give me some kina price your looking to spend I will check areound here. If they have anything ill get you some contact info. Not interested in being a middle man in payment or shipping, but glad to look around here for you. Like I said, im in houston and work in the industy, so I see them around alot. If your interested just send me a PM
Lionel C
Lionel C
Lionel C
Lionel C
I think for 1500 to 2000 you can get something pretty nice. My dad has an imported mill, fully manual, with a 220volt motor. It works really nice, and he bought it used for less than 1000. You should be able to afford above the average Harbor Freight deal. Look around at some tool shops, or keep an eye out for used equipment. I would recommend the used route. If you don't go for a used Bridgeport, it will probably be an Asian import.
Do not get a harbor fright mill they are hard to get parts for and are just generally not worth anything. Get a used bridgeport or acer. Acers get a bad rap but they are generally good machines.
6 & 8 Second Club
I also have been planning to get a small mill after the new shop is done.
I get that a used bridgeport is better than the low end stuff at harbor, but are you guys also recommending a used bridgeport before a new so called top of the line import?? Thanks.
6 & 8 Second Club
Talking to a guy last week, he has a vert & horiz mill plus a lathe, what would any of you that know better recommend 1st. Just used for maintaining our cars & any changes that we make and might do ourselves. Tired of waiting month's for every little thing from the chassis shop. Thanks.
Here are a couple of suggestions. Go the Yahoo Groups and join the "drillmill" group; there is lots of info on bench top mills. Another place to look is Grizzly, they have a whole line of quality mills. My suggestion would be a 12 speed, with the largest table you can afford, and the longest quill stroke. http://www.grizzly.com/catalog/2007/Main/544 The most of the mills from Taiwan are of good quality, the stuff from China is hit and miss.
I had a bench top machine for several years (before moving up to a Bridgeport style mill). These work great for projects that are not too much bigger than a shoe box. Do be prepared, that over time, you will need to spend about $2,000 for all of the tooling, to make this machine perform.
Here are of couple of forums to look at also:
http://www.chaski.org/homemachinist/
http://www.practicalmachinist.com/cg...ultimatebb.cgi
http://bbs.homeshopmachinist.net/
Home Shop Machinist magazine, along with Machinist's Workshop magazine (both from Village Press) have get ads and articles.
Hope this helps!
Hope this helps!
