Got A Question For You Welders
In a lot of cases vertical ups can be just plain ugly no matter what you do with the exception of using a few stick electrodes which don’t flow as much as others, but a lot of the question is what are you welding, how heavy is it and what are you welding it with?
Remember that you dont need as much heat running up as you would running down or flat. If you start getting cratering, or a crown in the center hold your sides longer and slow down. Turn you machine to about 160 amps and go from there. That would be a good setting for .035 wire and C25 gas. If you are using C100 gas you dont need as much heat. Try it and post a picture, I can tell you what you need to change if needed.
i think hardwire MIG welding WAS invented, or perfected through shielding gas usage, so that any monkey could pick up a gun and stick two pieces of metal together. that's the point, BUT even still there is a right way and a billion wrong ways to do it.
i basically build radiators for nuclear (and othe fuel) powerplants at Thermal Engineering, Intl. there's a lot at stake when it comes to the quality of my welds and everyone else's that work there. i had to pass a X-ray test on several processes and in many positions including hardwire vertical up. i gotta say, that was probably the hardest to do just because of nature of the puddle under those conditions in that process.
i've never welded hardwire up since i took that test.
Thats exactley whats going on here. The main crew leader as far as welding goes is from the military and I think thats how thei whole hot tack method came about. Everyone in the shop just praises this guy and thinks hes the best builder to ever be and he cant even do a vertical up. The sad part is he acts the same way, has the cocky attitude like I am supposed to bow down to him and that just bothers me.
But Yeah MikeGyver the welds we are doing are very important. We are building Mining Equipment, the big chipping plants, washing plants, and screeners with a lot of mass, most of our plants leave the shop at over 125,000 pounds. I dont think I could or want to deal with the fact that one of my welds could break killing someone just cause they wanted they're welds done a shotty way cause most of their team leads could not weld properly. That is why I wll be looking for a new job here real shortly.
When I started another welder started with me and he was certified and everything and when he found out that they did this hot tack crap he was about ready to walk out right there. They put both of us on this project and we welded the way we wanted to and the next day the shop superintendant was there along with this "military" leader to tell us we were doing it wrong and that hot tack is soo much better and stronger and then they proceeded to make us do it the hot tack way. Ever since then I have been very questionable on the quality of their work. I am just not sure I want to be a part of it anymore, theres ather places I could be working I am sure. Sorry for the long post guys, I'll try and get ya some pics also, I dont know how well they'd like me takin pics of their welds but oh well.
-josh
