Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Dremel Tool opinions please???
Old Oct 5, 2007 | 10:03 AM
1FSTLS1's Avatar
Default Dremel Tool opinions please???
All,
I am looking to get a dremel tool for doing the wheels on my 81 Trans Am and want to have it around for various future projects. What do you guys recomend or have likes and dislikes please.
Old Oct 5, 2007 | 10:14 AM
00SS!'s Avatar
Are you going to use it to polish them? You would be better off buying the small powerball and gettin some Mothers polish.
Old Oct 5, 2007 | 10:21 AM
1FSTLS1's Avatar
No they need to be cleaned re-done ect. Also any comments on the mothers $20 polishing ball. Was thinking of one of thoes too.
Old Oct 5, 2007 | 05:35 PM
budhayes3's Avatar
PT's Slowest Truck
I wouldn't use the dremel for big projects, but it's awesome for interior work (like stereo installs and shaping abs plastic), small around the house stuff, light duty cutting and shaping in tight areas, etc. I use mine all of the time, and recently got lucky and picked up a second one at a garage sale for 5 bucks!!
Old Oct 7, 2007 | 03:12 PM
The Black Mamba's Avatar
I use one that I got for a gift a while back. I think it is from Hobby Lobby or something. Whatever. It seems to work pretty well. Although, I haven't really used it too much, it does do the jobs I have tried with it.
Old Oct 9, 2007 | 11:21 PM
jimmyblue's Avatar
Moderator
Dremel will eat you alive for consumables, and it's just a tiny
tool. If you want low speed get a cheap corded variable
speed drill, the lighter the better, with trigger lock-on and a
**** of some sort that will let you dial up a set speed. This
is way better for polishing, you can use 2-3" buffs and any
1/4" shank tool. If you want high speed you can find electric
die grinders on eBay for like $10 that will out-chow a Dremel
big time. Odds are you can get both for the price of a retail
Dremel "hobby kit". And the 1/4" shaft tools are so much more
rugged, effective and usually cheaper.
I have a few Dremels but very rarely use them. Though I did
have a square inch sized bit of wood that needed sanding the
other day, and the oldest Dremel was just a champ.
Old Oct 19, 2007 | 08:38 PM
76LS1BIRD's Avatar
Restricted User
If you have air, a 1/4'' air die grinder works well.
Dale
Old Oct 19, 2007 | 09:46 PM
lgobraves's Avatar
good for small jobs....anything else and it's way underpowered
Old Nov 1, 2007 | 06:51 PM
chromeplated500's Avatar
yeah not for polishing.... it would be cheaper to buy a couple power *****... I spent a fortune gettin different attachments... which is pretty cool. But I still went and bought a high speed air (dremel) for bigger projects.
Old Nov 1, 2007 | 09:14 PM
Sunset01SS's Avatar
I think everyone should have a Dremel but as stated previously, for larger grinding/sanding it's not the greatest. It came in very handy when I had to trim my Fuel Rail covers, cut out my lower air box, grind small rust spots, etc.
Old Nov 3, 2007 | 04:12 PM
koolaid_kid's Avatar
To answer the original question, I researched Dremels prior to my purchase. They come in various power ranges, accessories and such. I chose the 395 Multipro model. It has a switch for different speeds, comes with a few bits, and has a carrying case. It also had the most power of all the Dremels that I looked at, and will actually torque (rotate) in your hand when you turn it on. Being able to switch it to a specific speed was also a bonus, versus having to hold down a variable speed lever.
Cost was around 50, and is good for what it was designed to do. Although I like my air grinders also, they cannot fit in tight spaces like the Dremel, and there are times when I do not want to be running my compressor.
So, like every tool ever made, it has its place.
As an aside, I bought a dremel bit set from Harbor Freight. Cost was only 10, and it looks to have some decent grinding and polishing bits. Yet to be determined, however.
Old Nov 9, 2007 | 09:56 PM
FireSilverLullaby's Avatar
Yeah dremels are good for small spaces and usually light work. I try to use somtheing else when i can cause i go though those bits and attachments like crazy.
Old Nov 9, 2007 | 10:48 PM
KillerZO6's Avatar
i got 1 and it come in handy all the time
Old Nov 9, 2007 | 10:55 PM
car_fixer's Avatar
for big projects a dremel is not the best choice, it will overheat after a short while, i fried one of mine doing a carb main body. the best choice would be an air powered polishing tool like this
http://www.thetoolwarehouse.net/shop/AP-3059.html
i polished the rear rims for the race car with a drill and a power ball like product, and i thought they came out good, the front wheels were in worse condition, and the power ball wasnt cutting the oxidation well, so me being a tool *****, ordered one from the tool truck, and it made the rear wheels look like they were out in the weather for a few years, i was able to do a better job on a worse condition piece in half the time, i am a beliver now. this tool spins slower than a 1/4 inch die grider but has alot more torque, so you can lean on it alot. it comes with everything you should need except elbow grease. you could get a electric 1/4 die grinder also and polishing bits, but most of the time they are smaller than the ones in the polishing kit. now for r/c car engines, the dremel tool rocks, and thousands of other uses, but for big stuff , use a bigger tool, oh and post before and after pics if possible
Old Nov 11, 2007 | 08:50 PM
budhayes3's Avatar
PT's Slowest Truck
I was thinking of this thread yesterday as I was using my dremel to form some notches in the red plastic box on the L/S of the truck engines that serves as a junction for the battery cable/B+ wire to the alternator. It was perfect for what I needed to do and the job came out perfectly
Old Nov 12, 2007 | 07:44 PM
01ssreda4's Avatar
it comes in handy but mine gets hot as a mf after using it for a few mins. not something im used to after using die grinders.
Old Nov 12, 2007 | 08:53 PM
KillerZO6's Avatar
ive used mine for a couple hrs and it didnt get that hot
Old Nov 13, 2007 | 07:31 AM
ghettocruiser's Avatar
I use my dremel so much I stopped putting it in its case. I just hang it on the bench. I use it a TON when I do re-gearing. I use it with a little drum sander to make set up bearings if the carrier shims are under the bearings. I also cut off old bearings, I dont press them off. I use one little disc, and cut off 3 bearings (2 carrier, 1 pinion). I used it for trimming my FRCs as someone else mentioned.
Its just one of those tools that I think everone should have. Just like a 4.5" angle grinder.
Oh...and I should mention Ive had mine for around 12 years now. My dad got it for me when I was into building models and what not. Never even had to replace the brushes...
J.
Old Nov 14, 2007 | 04:40 PM
01ssreda4's Avatar
i got a fairly new one bout 1 year old. it gets so hot you gotta put it down bc the fan blows out wicked hot air.
Old Nov 14, 2007 | 09:01 PM
KillerZO6's Avatar
u should call them about that it not suppose to do that
