Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Home built work bench
Old Feb 14, 2008 | 01:38 AM
JUICED96Z's Avatar
Default Home built work bench
Post pictures of your home built work benches.
Wanting to build one out of 2X4's with a storage area underneath thats open.
Old Feb 14, 2008 | 06:34 AM
black01_WS6's Avatar
I am going to be building one that folds up to the wall, and doesn't take up a lot of space. It will be a big work bench that won't take up a lot of room, and it makes me put away my tools after use.
By doing this I am able to have space for the riding lawn mower inside the garage.
Old Feb 14, 2008 | 01:04 PM
SOM WS9's Avatar
I was planning on building a bend that folds up to the wall too. It will be a while before I get it done though, I'm closing on the new house tomorrow. Post pics when you get done.
Old Feb 15, 2008 | 11:35 AM
PAGregSS's Avatar
I just bought a whole bunch of 2" square tubing that I'm going to be cutting and welding together for a workbench. Should last me a lifetime.
Old Feb 15, 2008 | 08:50 PM
BADD SS's Avatar
!.25 " thick 4' x 8' 1.25 " thick steel top, with 8" I beam legs, welded the height adjusters on after the pic... Nothing like a strong workbench you can jump on the corner, and it doesnt budge. 1896 lbs when finished.
Old Feb 15, 2008 | 08:57 PM
Jpack's Avatar
Old Feb 15, 2008 | 09:33 PM
EastTnZ28's Avatar
At least its not heavy Im thinking of building one similiar to yours. I know what you mean about a sturdy work bench. Nice job. Hope you have alot of friends or a forklift.
Old Feb 15, 2008 | 10:18 PM
PAGregSS's Avatar
And I thought 2" square tubing was overkill. I'm also putting heavy duty industrial 4" casters on the bottom of mine so I can roll it around the garage. I bought enough so I can do a 60"Wx36"Hx36"D.
Old Feb 16, 2008 | 07:59 AM
BADD SS's Avatar
I have a crane on the back of my pickup for just these things, so, I flipped it, and welded 1000lb 6 inch casters on it, so I could roll it around the shop, and then twist the adjusters to take the weight off the wheels, and level the table.
It's about the most usefull thing I have ever made... Now im working on a 32' gooseneck two car hauler....
Old Feb 19, 2008 | 02:39 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
If you look I have three 2x4 braces at a 45 degree angle that support the 5 2x8s that are bolted down. This leaves plenty of space to collect crap underneath as well as park my John Deere under it as well in between the two cars.
Old Feb 19, 2008 | 03:25 PM
jetlag's Avatar
As you can see, I still don't have tops for the bench, so everything is strategically set on the 2x4s..haha I'll finish it one day. It will also have shelves under neath, and I left an open spot for stools to sit near the bench. It is 12' long on the long side, 8 on the other.
I can still easily fit my Camaro and another car in the garage.(but in the pics the Z28 is more towards the center)
Old Feb 22, 2008 | 04:17 PM
Schnell's Avatar
This pic is from 04. I have a ton more tools now including a vise attached to my bench.
Old Feb 25, 2008 | 01:47 PM
ckyconan2003's Avatar
Originally Posted by Jpack
i applaud you sir, made me laugh.
Old Mar 1, 2008 | 05:07 AM
samanthablack87's Avatar
Am i the only one working outta the back yard with lean 2's and cardboard in the mud as creepers?
Old Mar 1, 2008 | 10:59 AM
B18CYA's Avatar
1/8" plate steel and two pieces of 1/2" mdf stacked, one sheet cut in half
Old Mar 1, 2008 | 11:35 AM
99blancoSS's Avatar
I used 2x6's and 3/4 inch plywood. Works great been up for 8 years now.
Old Mar 1, 2008 | 08:42 PM
JUICED96Z's Avatar
Got the keys to the house and need to do some measuring. Before I build it I need to account for another car being in there in a few years.......
Old Mar 14, 2008 | 09:59 PM
Dave 96TA's Avatar
Any more pics? I want to build a small bench to fit a grinder and vice and still have a little working space. I can't fit much in my shortened 1-car garage.
Old Mar 15, 2008 | 12:46 AM
bearcatt's Avatar
That's not a work bench, it's a WORK BENCH !
Old Mar 15, 2008 | 01:03 AM
bearcatt's Avatar
