Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What makes car jacks fail?
Old Mar 24, 2008 | 12:00 AM
RobZ's Avatar
Default What makes car jacks fail?
I have one that just doesn't work like it used to,I mean it lifts,but not as strong as it should.Ive seen others do the same thing.Are they rebuildable?orings,fluid,or just no bueno any more and buy a new one.
Old Mar 25, 2008 | 11:06 AM
chromeplated500's Avatar
I would imagine seals. because its all hydraulic, meaning that it wont hold a seal.
OR you might need to fill it up with more oil. I had to do that in one once..
Old Mar 25, 2008 | 03:30 PM
mrdragster1970's Avatar
6 & 8 Second Club
Most jacks are rebuildable, & as most things with fluid, they do leak as they are used.
Old Mar 25, 2008 | 04:03 PM
RobZ's Avatar
Ive tried to fill one up,but squirted all the Hydraulic fluid out some rubber access plug.I also tried other access holes,but no use.Is there a way to prime the air out?This seems to be the issue with one that I have.
Old Mar 25, 2008 | 08:51 PM
xfactor_pitbulls's Avatar
Raise your jack up to full extension, hold or block it there, then remove the drain plug. Of course try and get the cylinder level so you can get fluid in it.
Old Mar 29, 2008 | 11:31 AM
davered00ss's Avatar
Moderator
Mya just need more fluid or a seal. Nothing big if it's a good jack.
Old Mar 31, 2008 | 05:52 PM
Brismo7's Avatar
is there a way to increase/decrease the rotating bar sensitivity, one of my jacks is a decent jack, but when i raise it up put jack stands under the car then go to lower the hydrolic jack, the bar tends to be hard to spin, and i try to go slowly, but it seems to stick, then boom, the car falls quickly and i have to quickly jerk the bar back to stop it from slamming the car down.
sorry if this doesnt make sense. any tips??
thanks!
Old Mar 31, 2008 | 09:52 PM
6 & 8 Second Club
Makes perfect sense. I have one exactly like that. We tried everything. It just has a huge drop for some reason.
I actually marked the handle so we only use it on trucks. I never get under it, don't trust it.
Great thread, hope a hydraulic guys shows up.
Old Apr 1, 2008 | 11:47 AM
1CAMWNDR's Avatar
My floor jack stopped working on me Thrusday with the car up on 4 jackstands. It would not lift the car up enough to lower the stands. I ended up running around to all 4 corners 4 times with a cement block and the spare tire scissor jack slowly letting the car down a couple notches at a time. What a pain.
Old Apr 2, 2008 | 07:17 PM
redbandit98's Avatar
its usually not enough fluid. Most of the time people never check the jacks and they slowly leak fluid out until finally its just enough to get you started but not enough to lift it to its full capacity. Just put some hyd. oil back in it and it will be good 90 percent of the time. Try to make sure its level and if your not sure, just put small amounts in at a time. If for some reason the seals are gone in the jack, they can be rebuilt fairly easy if you can find a kit for it.
Old Apr 3, 2008 | 07:01 PM
mikenews's Avatar
There is also a ball and seat that sometimes is the culprit. Also you also get what you pay for. I have Lincoln (snap on) jacks in the shop, used daily for over ten years without a single problem.
Old Apr 3, 2008 | 10:46 PM
GregWS6&z28's Avatar
it's not just regular oil in there either. has its own jack fluid (haha)
Old Apr 4, 2008 | 10:00 AM
PewterScreaminMach's Avatar
Ha, jack fluid.....
Anyways, mine stopped working well the other night while I was pulling the tranny. It just stopped jacking up high enough to pull the stands out, so I filled it up with tranny fluid and it works well now. Still feels a little different, but that's probably because I didn't know to jack it up all the way before filling it. I may need to redo it that way and see if it feels a little better. Either way, it works now.
Old Apr 30, 2008 | 12:08 AM
VETTEX2's Avatar
That is why I have 5 jacks and a lift
Old Apr 30, 2008 | 05:00 PM
Brismo7's Avatar
can you use brake/clutch fluid?
cuz i got some laying around...
Old Apr 30, 2008 | 07:48 PM
eastcoastbumps's Avatar
Yes, I have a friend that uses brake fluid in his.
I have a Craftsman aluminum that I exchange every year for a new one.
Old May 1, 2008 | 12:13 AM
terryr's Avatar
A neighbor threw out a nice 3 ton, and I found that the cheap metal on the bypass screw wore down against the ball bearing seal. Took it apart, welded a new tip on it, and it works great.
Old May 2, 2008 | 10:07 AM
1CAMWNDR's Avatar
