Anyone use this? Stanley Rotator ratchet..
http://www.stanleytools.com/default....otator+Ratchet
You twist the handle, and the socket rotates, or you can use it like a conventional ratchet.
Seems like it would come in handy during plug changes.
Anyone use one?
a friend of mine has that exact ratchet, and between it and the blue point, the blue point feels like the mechanism is stouter; the stanley weaker but with more gear teeth(less movement to make it ratchet.) the blue point has an all steel handle with some knurling, the stanley with a semi-hard rubberish plastic for a handle. the only thing I dont like about the blue point model is that the forward-reverse selector is a plastic cap, I havent broken mine, so I guess it is pretty durable still, as ive dropped mine a few times, but I was a little dissapointed in the fact that something snap-on sells has a plastic piece on it.
Id reccomend having one. once you have the bolt broke loose, you can finish twisting out the bolt just by rotating your wrist back and forth, as the handle also ratchets on both models.
I think snap-on discontinued the blue-point model - snap on driver told me the head was too large for some areas or some other kind of bullsh*t, whatever.
but, you can find it on ebay where people are liquidating a bunch of em for pretty cheap prices. with all the ones that show up there lately, ive seen em go for as low as twelve bucks and as high as forty, either way a pretty good deal. i think it was called a rapid ratchet in case you wanted to search for it on ebay.
its mainly something I use to finish pulling out a hard to reach fastner once its broke free.
like the above poster said, its great for something like a spark plug, where it can be hard to reach em with anything but a socket, and once you go beyond that point where there isnt enough resistance to counter-turn the ratchet, you can still finish unthreading the spark plug by twisting the handle.
I'll check out the Husky one, but for 25 bucks, the Stanley one seems like a decent deal.
