What floor jack to buy?
Anyone have any recommendations on a brand and where to get it? Thanks in advance.
I personally use a "standard" floor jack on my car.....the trick I use is to first take the "factory" jack (scissors POS), put it under the subframes (anywhere along them works) and pre-lift the car just enough that I can get my floor jack under the subframes (does not take much). Then I can lift the car with the floor jack and do whatever work I need to. When I get ready to lower the car, I slip the scissors jack back under the subframes, let the car down on it (so I can pull the floor jack out) and then lower the scissors jack.
This sounds a lot harder than it really is. It probably adds 30seconds more to my project.
http://www.partsamerica.com/PartDeta...egoryCode=3397
I have the jack on there called the DK-20. I LOVE IT it's great and works awesome. Was well worth the money if you ask me. It is only 3.1 inches at minimum and fits under the car great
Will
JR
Will - Do you have the quick lift pedal to go with it? If so, how do you like that? TIA.
Glad to see u joind KSFBA Toonz
Will
JR
Will
I'm sick of bringing my big jack to the track.
BTW - The height is 3.5 inches from the ground to the "rubber puck".
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
There's also a little info about them here
http://www.bmw-m.net/Digest/Archive_...gest2536.htm#6
I had found another link about them but it's not working anymore
Will
