Fix on 2 broken floor jacks
If the fluid is on the floor, pulling plug & refilling is a waste of time. It's the same as an engine lift, the cylinder lost it's seal.
Pull apart & see if someone can match it locally or call them & see if they sell seals to the public. Good luck.
I could not get the cylinder apart.
The top of the cylinder had a hex cap on it, so I would "assume" it would unscrew. No luck at all, it did not budge. Even mounted in a vice and beat upon with a sledge, no movement.Looks like I now have a jack's worth of scrap metal.
Well after paying thru the nose for one of these I found out that it's the same as the old Licoln jacks from years past. If you look up in the phone book under hydraulics you can find guys who sell fix and repair jacks. I bought a good jack Licoln jack from the guy here in AZ for less than half as much as the Snap on.
just my .02¢
My garage must be dusty enough that I keep wiping out the seals.
