Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
How to do TOE Alignment?
Old Jul 25, 2008 | 09:22 AM
Stampede4ever's Avatar
Default How to do TOE Alignment?
Looking for an easy way to do it.
Thanks.
Old Jul 25, 2008 | 10:58 AM
jimmyblue's Avatar
Moderator
On my beaters I used to just do it by eye, sight
along the leading and trailing tire faces and crank
on the adjuster until it "points" at the rear tire
face. Good enough for 20Kmile tire life, for me.
But I have higher expectations for the Camaro's
handling.
Old Jul 25, 2008 | 11:43 AM
Camaroholic's Avatar
I've used fishing line tied to two jackstands, one at the rear of the car, one at the front. Parallel up to the rear tire, then start working on the front adjusting the tie rods. Helps to put the front wheels on some thin metal plates that are sitting on a very thin layer of sand (helps the wheels turn). Or you can get toe adjustment plates for $100-$200 (ball bearings and an arrow for the angle).
Old Jul 25, 2008 | 12:44 PM
I've thought about making some Toe-In Plates out of Lexan. And trying it that away.
Thanks.
Old Jul 25, 2008 | 01:05 PM
jimmyblue's Avatar
Moderator
Could get a couple of large Lazy Susan bearings
from Home Depot, pretty cheap.
Old Jul 25, 2008 | 03:06 PM
black_z's Avatar
On our formula SAE car I bolt a straight edge to the hubs and tie a string behind and forward of the axle centerline the same distance as the overall wheel radius. From there it is a few measurements and some simple math and you are able to adjust.
Old Jul 25, 2008 | 10:42 PM
88SS LS1's Avatar
You can also measure from both inside lips of the rims and adjust the tierods, till you get the correct measurement you are looking for.
Old Jul 26, 2008 | 01:31 PM
CTSmechanic's Avatar
You want something very rigid esp. since your dealing with 1/16ths of an inch http://www.longacreracing.com/catalo...id=152&catid=5
Old Aug 4, 2008 | 11:23 PM
chpmnsws6's Avatar
two boards and a tape measure. Toe is easy, caster/camber are the hard ones
Old Aug 8, 2008 | 07:35 AM
yomama's Avatar
Yea what he said, but if your hard up you could even use the treads themselves although you would ideally like something that would provide a rigid reading. But if you have to getterdone then just use a tape measure on the straightest treads possible.
