User Support & Resources Account Problems | Questions | Suggestions
Posted time on post, PM, etc is off by a +1 hour
Old Jan 5, 2010 | 01:31 AM
Devils Mentor's Avatar
Question Posted time on post, PM, etc is off by a +1 hour
Is this a new issue, I never noticed it before. All the are ahead an hour in time for me; I just posted a PM and it shows 3:16am instead of 2:16am.
And yes my setting are correct, lol.
DM
Old Jan 5, 2010 | 03:04 PM
JeremyT's Avatar
Time displayed is based on server time as well as your settings in your UserCP and even DST settings for your own computer. While vBulletin gets the time from the server, settings in your UserCP and DST settings on your own computer is then applied. If the server time were to be off, it would affect everyone. I'm showing the correct time and I don't see anyone else reporting the issue to suggest the server time is the issue.
If the time is off for you, go to UserCP, Edit Options and Scoll down to "Time Zone" and select the proper time zone. Make sure your DST in your own computer is properly selected as it can also be used to adjust the time you see on the forums.
Old Jan 5, 2010 | 07:41 PM
Well Bro, I don't know what the deal is then. My PC is good and my setting here are correct for EST (Florida). I do know that this is new since I recall not having this issue on the recent past. Oh well...
Thanks for the post Bro!
DM
Old Jan 5, 2010 | 07:54 PM
JeremyT's Avatar
What is the DST Correction Option value set to in your UserCP?
DM
Old Jan 5, 2010 | 08:05 PM
Auto detect
DM
Old Jan 5, 2010 | 08:35 PM
JeremyT's Avatar
Check your computer time/date, specifically. If you're in the wrong timezone setting, but have the correct time, you will see this error.
Old Jan 5, 2010 | 08:40 PM
Hmmm... i turned the DST detection setting to off and it worked...
DM
Old Jan 5, 2010 | 08:48 PM
JeremyT's Avatar
Which tells me that you either don't have the correct settings in your computer's system clock (DST and correct timezone), or there is something wrong with the detection due to your browser.
The detection only works correctly if your computer's system clock is set to the same timezone that you define in your UserCP, with DST being automatically detected, and your browser is not interfering with the detection in the footer template.
Your computer's system clock/timezone and the forum's work together to display the correct time.
Old Jan 5, 2010 | 10:09 PM
It might be my Firefox. I am using ver. 3.5.6
DM
Old Jan 5, 2010 | 10:13 PM
JeremyT's Avatar
I'm using FireFox 3.5.7, previously was 3.5.6 until today. No problems. No one has reported a similar issue. If the issue were server side, I'd be impacted as well as hundreds-thousands of other users.
Don't know what to tell you other than what I've previously disclosed. If the settings are correct in your UserCP, then it's your system/OS time/date.
Can you post a screen capture of your system time/date?
Old Jan 5, 2010 | 10:18 PM
Well since I set the DST to off, the time has been right, but where do I find my system time/date? Are you talking about the clock in the lower right corner? If so it reads 11:17PM, the correct EST time.
DM
Old Jan 5, 2010 | 10:30 PM
JeremyT's Avatar
DM
Yes, the clock in the lower-right corner is the computer's/operating systems clock that I've been referring to.
Just because your computer's/operating systems clock is showing correct, you may not have the correct time zone. Right-click on your computer's/operating systems clock and select Adjust Date/Time, select Time Zone tab and make sure you're in Eastern Time, and the option is enabled for Automatically adjust clock for daylight savings changes.
Your computer's/operating systems clock (lower-right corner) must be set correctly with the correct time zone (as I described above) for the forum to properly set your time stamp on the forum.
Old Jan 5, 2010 | 10:48 PM
Yeah, all that is good!
DM
