User Support & Resources Account Problems | Questions | Suggestions
Can't Find LS1Tech.com anymore
Old Aug 26, 2004 | 09:40 PM
DropTop98SS's Avatar
Default Can't Find LS1Tech.com anymore
Help! When I try to go to www.ls1tech.com from my home machine it searches for awhile and then says it can't find the page. The weird thing is that when I VPN into work, the same browser on the same machine will connect. Do I have something messed up on my personal machine or my home firewall that would cause the browser to think the web page isn't there?
I have looked at the software logs for EZArmor Firewall and nothing shows up about the site. I can ping it successfully, I just can't browse to it unless I VPN in. I don't have any proxies set. I think all the permissions are set to default.
Any ideas????
Chuck
Old Aug 27, 2004 | 10:29 AM
hefdaddy007's Avatar
Any ideas????
Chuck
yes somebody plaese help i have the same problem.
Old Sep 3, 2004 | 11:24 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
PM brains and see what he says.
Old Sep 6, 2004 | 10:33 AM
Brains's Avatar
You guys ever figure this one out? DropTop, if you're still having troubles I might be able to stop by your place some night after work and check it out at the source..
Old Sep 6, 2004 | 10:54 AM
I still haven't been able to correct the problem. Symptoms persist: browser resolves the server name but can't connect to the site/page unless I VPN to work. Then it works fine.
If you have some time this week and want to stop over that would be GREAT! I can make sure you are feed and beer'ed
Chuck
Old Sep 6, 2004 | 11:16 AM
NOSjohn's Avatar
Restricted User
Did they block your IP? Try re-setting your firewall, look specifically into the instructions on your software/hardware firewall...if you have one. Try deleting the software firewall and re-install...it may have created some entries. Can you go to any other site? Start with the basics first (which I'm sure you've done), I will try to help. Need more info. !
Old Sep 6, 2004 | 02:02 PM
Not that I am aware of but maybe my changing my subnet from 192.168.1.XXX to 192.168.100.XXX had something to do with it? I shutdown the software firewall and it didn't help. Plus, I can ping and tracert to the server. Brian set up a proxy for me on one of his other servers and I could connect through it.
Chuck
Old Sep 6, 2004 | 02:15 PM
NOSjohn's Avatar
Restricted User
Are you using DHCP by default or do you have multiple PC's set up on Static IP addresses? So, now you're only working via the proxy that Brian set up for you? To my knowledge, depending on if you're using a switch or a router and the brand, the IP should be 192.168.0.x or 192.168.1.x, nothing else. You manually changed the IP to 192.168.100.x?
Old Sep 6, 2004 | 05:56 PM
I am using DHCP. The box is a DLink Cable/DSL router/print server. The original subnet was 192.168.1.X but I had to change that manually to 192.168.100.X due to a conflict with the DLink box we use at work.
Old Sep 6, 2004 | 07:33 PM
Brains's Avatar
What part of town are you on? PM me your address, and a phone number and we can set up a night that works out for both of us.
Old Sep 6, 2004 | 07:34 PM
Mike K.'s Avatar
Just for the hell of it did you try a different browser? Also check the DNS resolution name of the VPN ip vs the reg IP. Maybe DNS is off somehow. Also are you actually able to successfully ping www.ls1tech.com? If so double check browser/firewall/DNS. If not try running a traceroute to see where it stops.
Old Sep 7, 2004 | 06:25 PM
maddboost's Avatar
I have the same problem sometimes with my work computer i think its the firewall settings we have here at work.
Old Sep 11, 2004 | 04:50 AM
02Z28LS1's Avatar
First thing to try is to reset all your browser settings. Delete all cookies, temporary internet files, set your browser to always search for newer versions of the page, set the security/privacy settings back to default, and make sure there are no proxies/auto-configuration scripts enabled. Even make sure "Automatically Detect Settings" is not enabled.
If it's still no good, try to ping the URL www.ls1tech.com from a command prompt and see if it resolves the name to its IP address (66.98.224.37). If not, you definitely have a DNS problem.
If it is successfully resolved from a command prompt, but the browser still will not go, then it's most likely a problem with the browser, or it's possible there is a virus on your system. Be sure to get all the latest virus definitions and thoroughly scan your entire system.
If you are using WinXP and are using DHCP, run the following commands from a command prompt, and reboot when done. If you have Win2k, don't worry about the last command. If you are statically assigning your network settings, be sure to write them down before doing it:
ipconfig /release
ipconfig /flushdns
netsh interface ip rest log.txt
After doing this and rebooting, you should have automatically obtained your network settings if using DHCP.....if you had a static IP, go back and reconfigure the network settings and try it again.
Old Oct 3, 2004 | 03:57 PM
5432LT1's Avatar
i had the same problem...what mine ended up being was i had spyware trying to redirect my browser..but i guess the link to the spyware ad was broken so it would just show up as website unavailable.
