1995 Camaro Z28 Big Block Project ( Near complete! )
This car is being built as a STREET car with track potential... it has everything but air conditioning.
*May Consider trades for 6 speed LSX car. trans am or camaro*
* Interested people should reply to my personal e-mail for quickest response, it goes straight to my phone* Sleeper95z1228@gmail.com
*Asking Price: $9,000.00 OBRO
*Vehicle City & State: Bridgewater Mass.
*Vehicle Make, Model, Year: 1995 Camaro Z28
*Actual Mileage:110K On body, 0 on drivetrain.
*Title: Clean
*Transmission Type: Automatic
*Body Color: Silver
*Interior Type and Color: Black Cloth
*List of modifications:
- 454CID Big block
- iron oval port heads
- mild cam
- edelbrock preformer RPM intake
- Holley 750 DP carb
- custom headers
- MSD pro billit mag. pick up distributor.
- weiand water pump.
- custom accessory drive set up.
- Nitrous works wet shot 125hp. ( not sprayed yet ) ( full bottle )
- Has Brand new TH400 trans, reverse manal valve body, and 3800 stall dynamic converter
Fuel system:
Holley black pump
-8 to pump
- 6 from pump to carb.
- 15 Gallon aluminum fuel cell with sender for fuel gauge
Nitrous has stand alone fuel system.
-6 feed from 1.5 gallon cell to N20 solenoid. fed by an additional black pump
Suspention/ chassis:
- Drilled and slotted brand new brakes in all four corners.
- UMI Tubular double adjustable tunnel mount torque arm
- UMI adjustable Pan Hard Bar
- UMI adjustable LCA's
- BMR K member, with stock rack and control arms.
- Thru floor frame connectors done by halls customs in Hanover Ma.
- big block is set up with motor plates from halls as well
- adjustable engine limiter
- LCA mount tabs are doubled in thickness and integrated with frame connectors.
- 20K mile 10 bolt 3:42 Posi MINT. ( ready for 9" some day )
Interior:
- Custom intstrument panel.
- B&M Shifter
- Near MINT grey cloth interior.
& much much more....
*List of known issues, flaws, or problems: Needs approx 2K worth of work to finish.
Needs:
- Hood
- Tires
- Driveshaft
- Brake Lines
- Mini starter
- Speedo, fuel level, and volts gauges.
- Radiator.
*Has the vehicle had any accidents or paint work? not 100% sure. i replaced the bumper cover and fender do to small tears in them. not caused from accident though. body is decent.
*Attach photos or post links to photos:
*Title: Clean
*Body Color: Silver
- 454CID Big block
- mild cam
- custom headers
Fuel system:
Holley black pump
-8 to pump
Interior:
- B&M Shifter
Needs:
- Hood
- Tires
- Driveshaft
- Brake Lines
- Mini starter
- Radiator.
Car looks good. I noticed your from bridgewater. Thats were Iam from. I moved down to florida awhile ago but its always nice to meet people from my home town. Ive got a black SS with blue flames up the nose. You might have seen it around up there before I moved.
i remember you justin...im scott...lj's neighbor. i used to have the blue 87 camaro with the silver racing stripe. last time you were at my house i had that big block sitting in a chevelle frame...remember me??
