FS: 02 Z28 M6 turbo project...
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $10000
Mileage: 65000
Private or Dealer Listing: Private Listing
Location (State): CT
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
comp hi energy roller lifters
comp ultra gold rockers
eagle 4340 stroker crank
arp headbolts
arp main studs
eagle h beam rods w/ arp2000 bolts
ross pistons
ross type 7 tool steel wrist pins
ross rings
clevite bearings
manley chromemoly pushrods
gm performance oil pump
cometic multi layer .051 head gaskets
manley stainless steel 1.6/2.08 valves
manley nextek dual springs
manley spring cups
manley Ti 7-degree retainers
fast 92/92
60lb/hr injectors
slp 160 thermostat
The engine was assembled and broken in by Superior Auto Engineering in CA. The engine made 630hp @ 4.5 pounds on the engine dyno w/ a vortech blower and a 92/92 intake setup. I have all the documents including pictures on the dyno, dyno sheet, build sheet and reciepts. This engine has 4,000 miles on it and is on its 4th oil change, which i switched to Mobil 1.
The car also has 4 brand new goodyear eagle f1 tires on stock 16" wheels. I personally just installed a new racetronix intank 255, a new umi k member, and a new bmr manual steering rack setup.
I will include with the car;
hp tuners pro with the 4 credits (the camaro ecu is fully unlocked)
custom built spearco twin core air to water intercooler 2-230 1500 cfm model
spoolin performance fabrication stainless turbo headers
california car cover
all the stock parts i took off it it including an ls6 intake and stock throttlebody
02 camaro Corsa catback exhaust I removed
truck manifolds and 2 2.5 inch stainless vband kits
The chassis of the car has a few performance parts mainly eibach sportline lowering springs, jegs bolt in frame connectors, upgraded eibach sway bars aftermarket struts, poly engine mounts and trans mount, edelbrock torque arm, solid lower rear control arms and an tubular panhard bar.
The overall condition of the car is great. Interior is nice too. I had planned on building a nice strip oriented turbo setup, but I just need to get out of my shop space!
If you have any questions don't hesitate to call my cell or text me. I will scan the sheets and reciepts I have tomorrow morning. In the mean time ill just post a few pictures here. Also feel free to shoot me any offers via PM only. If you didnt catch it from the body of this post the car is not running and is sitting on some skates covered in my shop. I will also follow up with some exterior photos and interior photos. The car is in really nice condition though.
Thanks again!
To the top... finishing this up, so it's getting closer everyday...
https://ls1tech.com/forums/forced-in...l#post15026433
15k as it sits.
15k as it sits.
