1993 mustang coupe Turbo LS swap!!
Year: 1993
Make: Ford
Model: Mustang
Price: $21000
Mileage: 5000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
1993 mustang coupe, Super straight body, Brand new paint(not a Cheap job either).Body and paint are 9.5 of 10. interior is 9.5 of 10. Car is from down south.
5.3 liter iron block ls motor
All ARP hardware including rod bolts and head studs
Z06 heads (243's) with a little massaging
All new valve train, crane dual springs (good to .675 lift), ls7 lifters, hardend pushrods, new valve seals, etc. etc.
Custom grind Lunati turbo cam (.651 lift)
LS9 head gaskets
Edelbrock intake manifold and fuel rails
120lb Seimens injectors
4150 Accufab throttle body
Extreme velocity hat
I.T.S. 76mm/96ar turbo
HP turbo kit modified to fit the ls (headers not manifolds)
Tial wg and bov
a2a front mount intercooler (hp stage 2)
3bar map sensor
Catch can setup
polished aluminum valve covers
tons of polished aluminum bits
Coil packs are hidden in the inner fender wells for a clean look
MSD wires
Built th350 tranny
Manual valve body
Hurst Ratchet shifter
Large cooler with fan under car
BBRC billet gas tank (beautiful tank, lol)
Dual walbro fuel pumps
Aeromotive fpr
-10an tank to engine bay, split into (2) -8an's to rails, -6an return
Auburn pro rear diff
Aluminum rear girdle
3.27 gears
31 spline axles
Alum. driveshaft
Baseline relocated upper control arm kit kit with adj. arms
Comp eng lower arms
Comp eng 3way drag shocks
4cyl springs (cut)
air bag
Full length subframe connectors
QA1 tubular k member up front
QA1 coilovers
flaming river manual rack
New black 'leather' sport seats
New headliner and visors
'custom' cup holder where stick shift was
Tons of billet trim bits
Autometer monster tach with shiftlight and recall
Autometer boost gauge
AEM wide band
Autometer, fuel psi, oil psi, water temp and battery volts
Laptop mount
Cd player
Pwr windows
Pwr door locks
Tinted windows
New Weld RTS wheels 15x10.5 in rear 15x4 front
275/50/15 Mickey street et drag radials (like new)
Smoked tails
Clear corners
Cervinis 4" cowl hood
Tuned with HP tuners
Compaq laptop with HP tuners and multiple pumpgas and E85 tunes Included with sale
Aluminum battery box in trunk
You build some nice cars let me know if this is something you might consider thanks http://chicago.craigslist.org/chc/cto/4358792521.html
Yes Stock bottom end.Should be Gen 4 rods as its a 05+ motor.
I will have to look and see if i have any pics of the under side and the trunk, if not i can get some but it may take me a day or two and the car is covered and in winter storage.
